oxygen and acetalene tanks
   / oxygen and acetalene tanks #11
That is the way it works around my neck of the woods also, without any problems, just swapping tanks once one is purchased for the first time.
Same thing here too...
SR
   / oxygen and acetalene tanks #13
Ditto.
One tip that may be helpful. If you can get (or already have) a small bottle, look at upgrading when you need a refill. Filling large bottles costs about the same as small bottles and lasts much longer. You will pay extra for the 'steel' as they call it, but it is very worth it most of the time. Typically you get the gas for free when upgrading, also. At least, that's how it works at my LWS.
   / oxygen and acetalene tanks #14
Ditto.
Same, which is part of the reason I upgraded. It costs them the same labor to fill a small bottle as it does a big bottle. So the gas in big bottles ends up running a LOT less per cubic foot than it does in small bottles.
   / oxygen and acetalene tanks #15
You folks that don't need to lease your tanks are lucky.
   / oxygen and acetalene tanks #16
You got that right Eric; at Sam's rate, my #5 acetylene and "T" oxy tank would've cost me $3660 by now, instead of somewhere around $200 (in 1978) -
If I ever start needing to heat a bunch of stuff I'll probly trade the Acetylene tank for a couple more Oxy's and swap what I need to for changing to propane - already have 4 25 gallon propane tanks that don't get used much at all, so the only cost would be new hoses (need 'em anyway) and a few torch parts.
Been DECADES since I've actually WELDED with torches, now with mig/tig/stick/plasma available it'll probly be NEVER... Steve
Well guy's here is where we are at now called my welding supply he gave me a price on 2 small tanks for $250.00 and I just take them back when empty trade for full sounded good right, so I load my big tank's take off to supply long story short he tried to pull one on me and it didn't work when he fixed my bill it was $476.65 I said how did you arrive at that number well this tank is this price and so on. Isaid to him you priced the tank's on the phone for $250.00 and now your wanting me to pay over double that, so now I have no tank's at all. The guy told me that they would not fill any customer owned tanks bigger than the small he was going to sell me. Thanks guys for all the info i'll keep looking at my options and come up with something[ARC3] is the supply company I was trying to deal with.
   / oxygen and acetalene tanks #18
No prob around here with owned tanks and you can even buy them used at auctions or estate sales and big welding shops honor things and refill.
I know why ACY should go out of style but what else can you get the heat from to heat steel hot enough to melt or burn parts off, etc? I didn't think propane could get that hot.
Yeah i'm in the dark here I was not aware that they were using propane to replace acetylene. Our problem is we only have one supplier here.
   / oxygen and acetalene tanks #20
1992 AM General M998 HMMWV 4x4 Humvee Truck (A55852)
1992 AM General...
2006 JLG 2030ES 20ft Electric Scissor Lift (A55851)
2006 JLG 2030ES...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2009 Ford E-450 Super Duty Ambulance (A55852)
2009 Ford E-450...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
