Need Help on Mahindra 7520 4WD (Electrical)
   / Need Help on Mahindra 7520 4WD (Electrical) #1
CuzPat62
Member
Alabama
2006 Mahindra 7520 4WD w/ ML 275 loader, bale spear, pallet forks, grille guard & canopy.
Today while bush-hogging, the light on my dash that is the battery symbol came on.
I turned tractor off several times and it started right back up but the light came on again every time.
At dark, I turned on my lights and finished the bush-hogging in the dark for about 1.5 hours.
When I got home I turned my tractor off and tried to restart it but all it would do is click.
The battery is drained.
Now my question is this:
Is the battery bad and that is why the battery light came on or is the alternator not charging the battery and thats the reason the light came on?
How do I know which it is?
I don't want to buy both an alternator and a battery.
Thanks for any help.
   / Need Help on Mahindra 7520 4WD (Electrical) #2
How old is the battery? Take it to an auto parts retailer and get it load tested.
It's around 1.5 to 2 years old.
   / Need Help on Mahindra 7520 4WD (Electrical) #4
Yep, get the battery load tested. Happened to my 5530,, Bad battery, replaced it and no issues since. That was 2 years ago.
idaho2
   / Need Help on Mahindra 7520 4WD (Electrical) #5
I think you are not charging. I cannot envision how a battery, which started the tractor before the work started, could fail so completely that the charging system turned on its light.
You need to invest in a cheap, less than $10 multimeter and measure the voltage going into the battery after you boost it to get started .
If you get such a meter, dont use it with the dial set as shown in the photo but rather at the 20 to the left of the center position.
I will be surprised if you measure anything like a high 13+ volts at a medium engine speed.
If you have a wiring diagram, plse post it so I can review.
Dave M7040
   / Need Help on Mahindra 7520 4WD (Electrical) #6
At rest check battery voltage, running check voltage(12.6).....It must min. over 13 volts(13.7-14.7) running to recharge battery....If not take it to a auto parts store and load check, either battery or alternator.
And of course you checked the water level of batteries lately?
   / Need Help on Mahindra 7520 4WD (Electrical) #7
Be sure to charge the battery with a plug in battery charger before you do any testing. The alternator is not designed to charge a dead battery, it is only designed to bring the battery back up after starting the tractor.
My bet is on a bad alternator.
   / Need Help on Mahindra 7520 4WD (Electrical) #8
I go with the alternator also. Charge the battery, check the voltage on battery, start the tractor, check the alt. output, if it is good buy a battery.
   / Need Help on Mahindra 7520 4WD (Electrical) #9
Check battery cables for corrosion, and make sure to check the negative cable where it grounds itself at the tractor frame or engine. It could be a bad alternator, but we really do not see many failures - more often, bad connections.
   / Need Help on Mahindra 7520 4WD (Electrical) #10
I completely failed to consider the cable connections to the battery and the starter/ground. Good idea and one of the first things to check before you start throwing money at the problem.
It would not hurt to clean all the connections with a wire brush even if they look good.
John Deere 6115D (A50120)
John Deere 6115D...
2015 CATERPILLAR D6T XL HI TRACK CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
