tips for lining up large (heavy) power/utility boxes when installing yourself.
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #1
disney
Gold Member
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
I need to install a large 80lb transfer switch for my mom's place. It is an outside box, with other weak plastic (sprinkler& phone) boxes beneath it, preventing an easy way support it. Ideally I would have it installed very close to the main box as 6 (2/0) wires run between the two at 2.75$ per foot, but I am concerned about getting the knock outs (therefore connecting conduit) lined up correctly. Remember this is a solo operation. Ideas?
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #2
Use plastic conduit. Boiling water softens it enough to scootch it over to correct errors.
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #3
A good hair dryer will soften the electrical PVC conduit.
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #4
If possible use an engine hoist to support the transfer switch. Making height adjustment are easy.
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #5
I use an RV scissors jack to hold heavy control panels while I anchor them. I added some pieces of 2x10 plank to both faces to get a bit bigger footprint.
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #6
Not sure what 200 amp. transfer switch weights that much but I pull the guts so I can mount the heavy ones.. pics would help..
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #7
Not knowing the complete "situation", could you temporarily screw a horiz. 2x2-4 at the lower (bottom) side? Once it's sitting on it you'll have one free hand to drive in some temp screws. You might be able to rest it on this 2x2 and jamb a diag. 2x4 or a shovel, whatever to keep it there just until you lag it on.:confused3:
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #8
Get a friend to help you or you will end up hurting yourself and breaking the other boxes.
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #9
I would mount the box on "C" channel lag screwed to the building studs. Once you get one bolt in it will be supported to get the others in and then move around as necessary to line up with connection points. That will also span the other wires conduits. Choices are to use either the 7/8 or 1 5/8" deep channel. Just one other idea.
Ron
   / tips for lining up large (heavy) power/utility boxes when installing yourself. #10
I mounted my 200 amp ASCO switch empty. Ran all the 2" steel conduit, pulled the heavy wires and then reinstalled the guts. Too expensive to damage or get debris and cuttings into the works.
2023 KOMATSU PC55MR-5 EXCAVATOR (A52705)
2023 KOMATSU...
SCAN TO RECEIVE TEXT UPDATES (A52706)
SCAN TO RECEIVE...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
