MAHINDRA 2538:
TractorData.com Mahindra 2538 tractor information
Mahindra 2538 has the same bare tractor weight and horsepower as my Kubota
L3560, which I use in woods work. If your land is flat 2538 is enough tractor to push over 3", not 5", Sweet Gums. If you will be operating on sloped ground consider increasing weight from 3,300 pounds, bare tractor, of 2538 to 4,200 pounds, bare tractor, of Mahindra 4500 series.
A 5" tree is ~~three times more resistant to pushover than a 3" tree. A 6" trees is four times more resistant to pushover than a 3" tree.
Trees uproot much easier after several days of steady rain, when tree root zone is nearly saturated with water.
For your primary task of woods management a Ratchet Rake bucket attachment will augment performance of FEL bucket and SAFETY of operation by gripping tree trunks with two rows of teeth. When
bare bucket slips, which happens, the potential for a tractor rollover is there.
Ratchet Rake is also optimum attachment for tearing out brush by the roots. U-Tube has many Ratchet Rake videos.
Woods work involves moving a lot of 700 pound to 1,200 pound loads, some heavier. You can drag such loads from the rear/center drawbar easily, but if you want to carry such loads cleanly and safely in the loader 4,200 pounds in the tractor will give you more stability. (Dirty tree trunks will dull a saw chain in less than one minute.)
The large rear wheels on tractors are a key factor in tractor pulling ability but at the same time make tractors inherently unstable, especially on slopes. Heavier tractors are more stable than light tractors. Enough weight for safety is particularly important until you have accumulated ~~400 hours of tractor operating experience.
Regardless of Mahindra model, if you will work on sloped ground have rear tires filled 3/4 with liquid, to lower tractor's center-of-gravity, and have rear wheels spaced as wide as possible when dealer assembles tractor wheels onto chassis. Four wheel drive is essential on slopes.
The optimum equipment to remove trees 5" and greater by the roots is a tracked mini-excavator, which can be rented. Heavy equipment on TRACKS is ten times more stable than heavy equipment on WHEELS. U-tube has many videos of mini-excavators tearing out whole trees by the roots.
SAFETY FIRST.
Buy ENOUGH TRACTOR for eighty acres.
