TIG-washing MIG welds
   / TIG-washing MIG welds #11
Well I can't believe I'm the first to do this, but maybe the first to post it?
This is probably illegal in 17 states (but common in Canada etc :D)
524895d1508130582-tig-washing-mig-welds-tigwash1-jpg
Since I'm no good at holding filler rod I welded this with the MIG
then whitewashed it with the TIG, & doesn't it look nice?
It's a stair railing.
Yep, On a Larger scale this was known as "Toe Dressing" or Tig Dressing". Often a Large amp Tig setup or more commonly a Plasma Welder on a Robot or Track would fix multipass welds to smooth and eliminate voids and or porosity. Common in heavy mine equipment and shipyards. I used sell a lot of this stuff to those folks.
OK thanks for that background. It was so dang easy I couldn't believe I'd pioneered something in a field as old as welding.:thumbsup:
Wonder why you don't hear more about the method (treatment)? Seems to me like relieving porosity is good, and it might reduce stresses too. Is it one of those slippery-slope kinda things, that can fool an inspector (or armchair inspectors)? Where a trained eye can't miss it and then suspects you're hiding something?
   / TIG-washing MIG welds #13
The impurities, voids and porosity were normally found by X-ray. After enough X-ray's showed the issue, They started Toe Dressing all of the heavy multipass parts. It was all about liability for the big parts. They were going on ships and huge mine trucks. I wonder if they should have toe dressed the welds on the Titanic or Edmond Fitzgerald. :eek:
   / TIG-washing MIG welds #14
I don't think the Titanic had ANY welds on it. At least not the hull plates. As far as I know they were overlapped and riveted. Some good welds, and perhaps a better grade of steel, Not to mention bulkheads that went all the way up to the ceiling, and she would have sailed into New York harbor.
   / TIG-washing MIG welds #15
Very interesting. I’m glad you started this thread, Sodo. Great insight from Yomax
   / TIG-washing MIG welds #16
Never thought of the Rivets. Probably as good as anything we do today. The Toe dressing was often done with a 600 amp power supply and a 600 amp Plasma Welder torch. All Thermal Arc stuff. 6045 Power Supplies and 6A plasma welding set ups. My experience was at NAASCO Ship Yard in SanDiego and Norfolk VA. And Joy Global in Milwaukee. Seems for some reason that after 5-6 passes on 2"+ steel, You start to get voids and poor X-Ray quality welds. So they go over the last few passes and re-liquidate them to repair. Seems dumb but it's a real problem.. Loved selling them the equipment tough. So as Sodo posted, I too employed the same thing to my poor welds. I have even went over my Tig welds with a tig welder and no filler. No I'm not a great welder like most of you. I'm just a lowly sales guy that enjoys weld smoke.
   / TIG-washing MIG welds #17
Apparently the Titanic used two different types of rivets Along the more open areas of the hull they used a good quality steel rivet and the heads were set with a very large hydraulic riveting machine. But in the more cramped spaces at the bow and the stern they used very much inferior wrought iron rivets that were peened by hand while hot of course. Many of these rivets were found to have slag inclusions when they were brought to the surface again decades later. This is attributed to the fact that the rivets were outsourced to many different mom and pop wrought iron makers that often turned out a shoddy product.
Lest anyone ask, I didn't really know these things, I googled them. I am crafty that way..:)
   / TIG-washing MIG welds #18
" I am crafty that way.."
James, if you wanna learn the RIGHT way you should google "craft" that are still AFLOAT... :stirthepot: ...Steve
   / TIG-washing MIG welds #19
I've been tig welding and hand slipped or coughed or sneezed enough to make a weird looking spot.
Normally a small grind where it occurred, then just restart.
But I have on occasion just stopped, put the tig torch back a couple ripples, used the foot pedal to manually pulse evenly spaced ripples up to where I start adding filler again, then continue on.
I'm sure lots of people do similar.
   / TIG-washing MIG welds #20
I don't know, James... I understand the Titanic hit the iceberg pretty hard. Maybe weld would have been better than rivets, and believe me, I am a strong believer in continuous join (adhesive bonding is part of my profession). Rivets are stress risers and holes are always the start points for cracks but an iceberg and momentum have consequences.
And Yo... any good salesman knows his stuff. I have faith in you... even if you are salesman. This coming from an engineer turned salesman. :D
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
2014 PETERBILT 386(INOPERABLE) (A52472)
2014 PETERBILT...
2013 BIG TEX 18 T/A UTILITY TRAILER (A52472)
2013 BIG TEX 18...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
