Soundguy
Old Timer
- Joined
 - Mar 11, 2002
- Messages
 - 52,424
- Location
 - Central florida
- Tractor
 - RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Unfortunately, since the internet is so vast and easily harvested, my idea for a potential commercial product would not be private very long. My apologies for needing to be somewhat vague. I won't become a multi-millionaire but there is a small potential market I've identified.
I hadn't considered it being a 'lawnmower' type throttle cable, I was thinking more on the lines of a bicycle brake or motorcycle throttle made of stranded stainless cable, but the concept holds water!
I can actually make a small batch mold to cast lead onto a wire pretty easily, so again this is quite viable and a route I'd really not considered, so thanks to those contributing thus far, it's been quite helpful.
something that actually comes to mind is a cavity press that is a clamshell of 2 chunks of aluminum with a small channel for the wire terminating to a small cavity where I place a fishing split shot and pinch it down in my 12Ton press, it's worth an experiment.
That's the swage setup I had mentioned earlier. and you could put a small eye in the rod that sets in the middle of the lead ball, to help hold it in. If you went the cast route, you can harden lead with tin, and arsenic and antimony. You could also move up to something like zinc.
