seijirou
I am having a hard time navigating what the least expensive tractor options are out there that offer a cab with A/C. Interestingly it seems that the smallest is not always the least expensive. For example the Mahindra "1538 HST Cab" lists $34k while the "2538 4WD HST Cab" lists $31k but is actually a little bigger.
I am fortunate that it seems every brand option has a dealer no more than 30 minutes from me.
I'm fairly sure I'm going to want hydrostatic because all my work will involve short trips. I also have no appreciable horsepower needs, 25hp is perfectly fine if such a thing exists.
Here's what I've found so far:
JD 3039R - $36,000 (2015 model used for $26k on machinerypete - also as far as I can tell the 1025cab doesn't have A/C)
Mahindra 2538 4WD HST Cab - $30,870 (used $26k w/ 8 hours on it on tractorhouse but 1k miles away)
LS XR4140HC (LS makes a 3135HC that is less expensive but I don't fit on it) - $29,777
Branson 3520CX - $27,995
Kubota B2650HSDC - $26,980 (2014 model used for $21.5k on tractorhouse)
TYM T354 - $26,500
Kioti CK3510SE HC - $25,975
EDIT: Deleted Cabela's. Google searches pull their page up but they quit selling them.
So right now in new the Kioti seems to be winning the price race, but a used Kubota is attractive even with that stupid treadle pedal. I am a little sketchy on buying used though because of the lien problem. I'm on the fence if that new premium is worth the peace of mind.
If you happen to know of other options I'm all ears. I also know there are some aftermarket cabs for various tractors and I'm fine with that too if they have A/C.
If you saw my other SCUT thread and you're wondering WTF, a SCUT is still on the table. I'm basically torn between the two, but I'm not in a rush so I'm just trying to go through my options. I want to try as best as I'm able to buy my 2nd tractor 1st. Thanks for reading
TYM T354 - $26,500
