Why are there so few rear discharge F Kubota mowers around?
   / Why are there so few rear discharge F Kubota mowers around? #61
Did the B3350 regen thing ever get figured out?
Some owners never have any issues, others (mostly in colder climates) are still having problems.
   / Why are there so few rear discharge F Kubota mowers around? #63
I'm So Glad I settled for the ZD1211 & steered clear of the Emission BS on ZD1511 :D
But that AirRide Seat is soooo comfortable.
   / Why are there so few rear discharge F Kubota mowers around? #65
Have them install an air ride seat on the 1211 and get to mowing!
Brett
Brett, how do you like your ZD1211 seat? Did you ever try a ZD1511 for seat comparison.
If I knew that everything needed, to make the air ride seat function, was self contained on the seat I’d consider it. I’m told that the AR Seat is about $1100. Sure would be nice if they’d offer it as an option on the 1211.
I’m going be Dealer tomorrow.
   / Why are there so few rear discharge F Kubota mowers around? #66
I’ve never seen a 1511. I like the seat on my 1211 it’s much more active than any suspension seat I’ve ever had. My tractor has air ride and it’s nice except for the bouncing makes it impossible to use the pedal smoothly so I set the throttle with the hand one.
Install this, just need some 12v from the battery and an in-line fuse
https://www.northerntool.com/shop/t...MIsYWw5sSh2gIV04SzCh2uGA1fEAQYBiABEgJIw_D_BwE
Brett
   / Why are there so few rear discharge F Kubota mowers around? #68
Brett
I’ve only seen one ZD1511. Ewald Kubota had one with 60” deck. Maybe ..... they’re mythical mowers?
The NT Air Ride Seat would interesting. Think I’d be banging my head on the ROPS.
   / Why are there so few rear discharge F Kubota mowers around? #69
Only reason my rops is up is because it holds the roof. However, I think there’s be plenty of room still. I’m 5’10” and have lots and lots of room. If my mowing took longer than an hour I’m sure I’d consider the air ride but for what I do it’s great as it is.
Brett
   / Why are there so few rear discharge F Kubota mowers around? #70
Brett
The point, I stumbled to make, is that the NT Seat is probably 8+ inches taller than the 1511 Seat.
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
Pallet of Assorted Hand Tools (A57454)
Pallet of Assorted...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
Predator 2000 Inverter/Generator (A57454)
Predator 2000...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
