Bigfoot62
- Joined
- Aug 5, 2008
- Messages
- 2,283
- Location
- W. Central Louisiana
- Tractor
- JD 5090M; JD 5085M; JD 5083E; NH TN70A; Ford 2600
. . . and I don't think I want a real light duty cutter . . .
You said it in the original post. You really don't want a light duty cutter unless the only thing you'll be cutting is grass. (and there are better implements for mowing grass)
I bought a "medium" duty 7' Rhino several years ago, and had to replace the tail wheel assembly, including the yoke, after the first summer. The yoke folded up. I called the dealer and he contacted Rhino. They said that was "abuse" and refused to cover it under warranty. Said I was using it on too large of a tractor. (100hp) Really? I wonder what HP tractor they thought I should put a 7' cutter on? I replaced it with a much bigger tail wheel assembly that was designed for a HD cutter. The sides of the cutter have also bent, probably where I've run into stumps or tree roots. I will NEVER buy another light, or even medium duty, cutter again.
My point is this: MOST manufacturers make a good HD cutter, and MOST also make light duty grass mowers. You get what you pay for.
Now, if you really want a heavy duty cutter, here's a link to the one that most utility company Right-Of-Way crews use: Brown Manufacturing You probably don't want to pay nearly $7k for a cutter, but I bet you couldn't tear it up if you tried.
