It may vary by state, but that's how much actual wood there is by definition. It would be pretty hard to measure though, without dipping it into a water tank. (So much for your dry firewood.What do you mean "taking out the air space"? I always thought a cord was 128 cu ft of stacked firewood. I always liked the barkless because that meant a lot more BTU per cord.
I致e never heard of trying to measure the actual volume of wood. I think it痴 technically illegal to sell a rick or truck load of wood, but that痴 what everyone does. I doubt most people would know what a cord is around here. And as mentioned above I sold a lot of truck loads of wood.
How could it be illegal to sell a truck load of wood. When selling the two parties have to come up with an agreed-upon price which doesn't make any any difference what the volume is.
Oh yeah. Just want to mention, there is nothing like a sharp chain. I currently run an MS270 which is legit. It’s a high end ranch/farm saw only to be led by the 290 and 311z. With that said, and everything I throw at it, it begs for more! Just keep the chain sharp and it eats the wood. Well, I’m no dummy, and since taking a loom at a pro stihl, I can’t get my mind off of it:. Will I weary my current saw out? Probably now! But will a new pro saw be more efficient etc? Especially considering over the rest of my life. Will I’d be worth the upgrade ? I’d most likely keep my current 270 and maybe even downsize the bar
To a 16” after she’s broken it.
Thoughts ? Anyone ?
It may vary by state, but that's how much actual wood there is by definition. It would be pretty hard to measure though, without dipping it into a water tank. (So much for your dry firewood.) You probably get more wood buying it cut and split than in longer lengths.
Measuring wood can be tough, as every time that you make it smaller it can be stacked tighter, hence into less space. After you take out the air space hardwood should have 85 cubic feet of actual wood; whereas softwood will have 96 cubic feet.
First, huh? Why would the density of the wood change how much volume of wood is in the stack? If a stack of wood is 128 cubic feet, the amount of airspace is only affected by the tightness of the stacking job and the size of the pieces. Second, I thought you were right about the split smaller can be stacked tighter thing, but it's not true. You can fit more wood in the truck (or any stack for that matter) if it's in rounds than if it's in splits. Once you split a piece of wood there's no way you can stack it tighter than it was when it grew. Bigger pieces equals less air.
I might have to test that theory. I知 pretty sure more split piece will fit in the truck. Youæ±*e right when applied to one piece, but a bunch of circles don稚 fit together very well.
Take a stack of wood 8' long x 4' tall x 4' wide. Cut it to length, split it, then stack it. It will take up less space.
I can think of several ways, most up here buy a 10 cord load of tree length and cut it right on the pile. My father really liked his old cordwood saw behind the tractor. I was always on the receiving end, right next to that open blade.
I've cut and stacked it in the woods, then gone in with my snowmobile and tote sled to fill my wood box every Sunday. One year I drove to Wilton and cut my brother's wood on the back side of his 12 acres; then my father brought it to the house with his ATV and trailer.
It looks like GG knows what he's doing.
Yes, I did mean logs. I knew that I would be kicking a hornet's nest when I made my first comment on cords; but it should lead to some good discussion. I took a wood scaler's course years ago, they said that firewood is the lowest value product and has the highest number of complaints.If by wood he means logs then this has been my life long experience but I don't know how to prove it with mathamatics or theories.
gg
You mentioned your coal/wood stove. Would that efficiently burn dry chips?I hear ya!
Growing up we used to fell the trees, buck them into 4 foot length, then load them onto a woods trailer, haul them out then pile them up. Then we would cut them as you did on a buzz saw. Then we would split the wood and let it dry. Then we would pick it up, put it into the trailer and haul it to the woodshed. My goodness the wood got dizzy being picked up and tossed around so much.
Now I am on the cusp of 100% mechanized firewood and it really blows my mind. We had to load that 4 foot wood with the big sticks on top so that people THOUGHT we had a log loader. It was stupid, blowing out our backs just for appearances!! Today my little log loader does the same job but is powered by a 6 HP lawnmower engine. My grandfather would die if he saw how effortlessly I move wood.
I have NEVER forgot where I started, it is what makes a person really appreciative for what they have.
I used to think I was getting royally screwed by selling wood by weight to the paper mills. One day I cut a load of 8 foot hemlock pulp for Jay and had stacked it up using the forks on my tractors. So I measured it. It came out to 13.5 cords on measurement.
After hauling the wood to the mill I checked thee weigh slip: I was credited 13.3 cords of wood. After that, I no longer considered myself being screwed by weight. Sure there are some variables. I can cut a 100% load of beech which weighs up more than the "average" cord of mixed hardwood, and this time of year when the wood is muddy, what normally are 10 cord loads ends up netting m 11.5 cord loads, but averaged out with some pure loads of lighter wood like Ash, the paper mill and I end up pretty square on the measurement I think.
I might have to test that theory. I’m pretty sure more split piece will fit in the truck. You’re right when applied to one piece, but a bunch of circles don’t fit together very well.
