Is there such thing as an electric cylinder to replace a hydraulic one?
   / Is there such thing as an electric cylinder to replace a hydraulic one? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a 6' snowblower with hydraulic chute and angle control and would like to use on a B7800 that has no remote valves. I'm not going t put them on it, either . I have other tractors with remotes but they don't work best with this snowblower. Electric would work on the B7800 and wish I could find electric cylinders to use in place of the hydraulic unit. Maybe electric over hydraulic? Are such things even available?
   / Is there such thing as an electric cylinder to replace a hydraulic one? #2
Re: Is there such thing as an electric cylider to replace a hydraulic one?
look at linear actuators.. Others here have modified the blower by using electric wiper or window motors.
   / Is there such thing as an electric cylinder to replace a hydraulic one? #3
Of course there are. There is a motor mounted on a little gear box, that spins a screw to move the "cylinder". We use them all the time and they work quite well. They are called electric actuators.
hank you for the info. Where do you look for these? Are some made to specifically replace the common 8" stroke hydraulic cylinder?
   / Is there such thing as an electric cylinder to replace a hydraulic one? #5
   / Is there such thing as an electric cylinder to replace a hydraulic one? #6
Those I've seen are light duty or very expensive.
Bruce
   / Is there such thing as an electric cylinder to replace a hydraulic one? #7
An alternative would be a small hydraulic pump and tank, like is used for trim and tilt on outboard boats.
   / Is there such thing as an electric cylinder to replace a hydraulic one? #8
Electric linear actuators are not less costly.
   / Is there such thing as an electric cylinder to replace a hydraulic one? #9
Northern Tool has some in various strength and length
   / Is there such thing as an electric cylinder to replace a hydraulic one? #10
To do the same work of a hydraulic cylinder, I'd think (no engineer) it would take a lot of amps to run one.
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
Honda EM3800SX Generator (A55851)
Honda EM3800SX...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A55852)
2006 Ford F-550...
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
American G-Model Pump Jack (A55315)
American G-Model...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
