Is there such thing as an electric cylinder to replace a hydraulic one?
   / Is there such thing as an electric cylinder to replace a hydraulic one? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a 6' snowblower with hydraulic chute and angle control and would like to use on a B7800 that has no remote valves. I'm not going t put them on it, either . I have other tractors with remotes but they don't work best with this snowblower. Electric would work on the B7800 and wish I could find electric cylinders to use in place of the hydraulic unit. Maybe electric over hydraulic? Are such things even available?
   / Is there such thing as an electric cylinder to replace a hydraulic one? #2
Re: Is there such thing as an electric cylider to replace a hydraulic one?
look at linear actuators.. Others here have modified the blower by using electric wiper or window motors.
   / Is there such thing as an electric cylinder to replace a hydraulic one? #3
Of course there are. There is a motor mounted on a little gear box, that spins a screw to move the "cylinder". We use them all the time and they work quite well. They are called electric actuators.
hank you for the info. Where do you look for these? Are some made to specifically replace the common 8" stroke hydraulic cylinder?
   / Is there such thing as an electric cylinder to replace a hydraulic one? #5
   / Is there such thing as an electric cylinder to replace a hydraulic one? #6
Those I've seen are light duty or very expensive.
Bruce
   / Is there such thing as an electric cylinder to replace a hydraulic one? #7
An alternative would be a small hydraulic pump and tank, like is used for trim and tilt on outboard boats.
   / Is there such thing as an electric cylinder to replace a hydraulic one? #9
Northern Tool has some in various strength and length
   / Is there such thing as an electric cylinder to replace a hydraulic one? #10
To do the same work of a hydraulic cylinder, I'd think (no engineer) it would take a lot of amps to run one.
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
Crawfish Boiler (A50860)
Crawfish Boiler...
Gravely Pro-Turn 152 Zero Turn Mower (A50860)
Gravely Pro-Turn...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
