Tractor loss of power
   / Tractor loss of power #1
JDEO
Williamsburg, IA
Branson 3820
Folks,
I have a Branson 3820. I went out to do the first mow of the season, and tractor is running smoothly. I start the mower up and get it up to speed on the RPM, get it in gear and it just doesn't want to go. engine is running smoothly, the mower is humming along, it just does not want to go at speed. The clutch seems to engage and disengage normally. there has only been about 45 hours since the last service. without the load on the PTO it seems to have good low end but as the RPMs climb the speed starts to struggle. Not sure What to look at. Fluids are up. filters on the Hydrauilics? or is this the beginning of the clutch failure?
Thoughts?
thanks,
JEff
   / Tractor loss of power #2
So the tractor just won't move, forward or reverse? "Doesn't want to go at speed?" Is the engine bogging down when it "doesn't want to go"? Maybe fuel issue, low fuel pressure, clogged fuel filter? Does your tractor have the DPF "soot cooker" exhaust filter on it? Maybe your filter is partially clogged? Is the DPF warning light flashing or steady on?
Slim,
No DPF too old for that. engine still runs RPMS seem normal. it acts like its in too high a gear when climbing a hill. just bogs down. I can understand the clogged fuel filter and starved for fuel but I don't believe that is it as it runs normal, idles fine. forward and reverses like it always has.
   / Tractor loss of power #4
Slim,
If I understand you correctly it starts and idles ad you can engage the pto and it will run up to pto speed fine but when you head up a hill it bogs down?
the rpm's drop?
Are you getting any smoke out the exhaust? black would be lack of air.
No smoke lack of fuel.
If no smoke change your fuel filter and verify your fuel flow to the filter.
If black smoke check your air filters, if you haven't. Should be checked and cleaned frequently.
A restricted fuel filter will let an engine run fine at light loads and choke it down when power is needed. As per Slowpoke Slim fuel is quite likely your issue.
   / Tractor loss of power #5
I’d guess it’s a fuel filter or less likely a clogged fuel line unless it black smokes when it bogs down. And check the parking brake.
   / Tractor loss of power #6
Lot of variables here but I would say if the engine runs and revs as normal and the tractor will move at normal speed on level ground but loses speed, while rpms stay the same (or especially go higher), while going up a grade then you have clutch issues. Perhaps as simple as an adjustment.
   / Tractor loss of power #7
Have you check air filter and radiator?
So last night I did a once over on the tractor. fuel filters are clean. air filters are clean. fluids are all up. same issues. engine is at running RPM PTO is engaged. ground speed in every gear 1-3, 2-2, 2-3 is the same under the load and tractor will stop if trying to climb a small incline in 2-3. disengage PTO and the tractor will speed up.
TO me it seems like it is Hydraulics or clutch... or brakes are not fully disengaging. am I off base here?
   / Tractor loss of power #10
If it was the brakes dragging it'd be the same with the PTO on vs off.
Do your tractor have an independent PTO, or live (two stage clutch) or transmission? Are you testing with an implement on the PTO?
"without the load on the PTO it seems to have good low end but as the RPMs climb the speed starts to struggle" could you explain that a little more?
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
205196 (A52706)
205196 (A52706)
2016 CATERPILLAR 336FL EXCAVATOR (A52707)
2016 CATERPILLAR...
