Buy Lincoln v250s
   / Buy Lincoln v250s #1
Tractorguy24
BC, Canada
Still looking for a tig...
Came across this :lincoln welder v25 s - Castanet Classifieds
Does anybody know anything about this welder? As far as I know it is a DC only. Will I be able to tig aluminum with it? Is it a disadvantage not to have ac for stick? Is it HF start?
Any advice is appreciated,
Thanks
   / Buy Lincoln v250s #2
You can, the aluminum has to be very clean before welding. I use 100% helium gas. This weld was made on DC, with 100% helium.
   / Buy Lincoln v250s
Thanks Shield Arc,
Is it also possible with argon or is helium a must? If i need to pay $200 extra to get another bottle it might be cheaper to get a ac machine if i ever see one.
   / Buy Lincoln v250s #4
I would recommend getting an AC Tig welder. Helium is very expensive, and you have to use more CFH. Because helium is so light.
This aluminum weld was made with my Miller Dynasty 300 on AC.
   / Buy Lincoln v250s #5
Thanks
If you just want it for steel (stick and tig) then it's an excellent machine. I have one :)
If your desire is to weld aluminum, I'd pass.
No high freq start. Needs a foot control or hand control to start the tig arc - or leave it on stick and scratch start the arc.
The price isn't super good - mine was $500 in near new condition with 360 feet of welding lead in near new condition.
   / Buy Lincoln v250s
I am wanting to lear both, aluminum and steel tig. $500 for a machine in new condition with that much leads is cheap. But then again, stuff is more expensive in Canada :(
   / Buy Lincoln v250s #9
Well, to be honest - the price I paid is ridiculously low on both sides of our shared border :D
The leads and all the quick connects pretty much cover the cost. Machine was basically free. ;)
   / Buy Lincoln v250s
Not related to my original question, but is it possible to stick weld with EVERY tig machine or can only some do it? If not all can do it, how might one find out?
2024 JOHN DEERE FC20M LOT IDENTIFIER 53 (A53084)
2024 JOHN DEERE...
LOT IDENTIFIER 235 (A53084)
LOT IDENTIFIER 235...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
(APPROX 24) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 24) 2" X...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
