Bridge Building
   / Bridge Building #11
Glad I could help! Can you sink in your telephone poles a little deeper? I wouldn't use wood buried in dirt though. Concrete is by far better for burial if it's in the budget!
"wouldn't use wood buried in dirt"......Why not?
Most electric poles throughout the US are wood, and they typically last 40+ years.
   / Bridge Building
Not in the budget! It's a very small stream. I could use a culvert just thought a little bridge would be nicer. Plus it's something my 12 year old nephew can do when he comes to the farm for his summer visit.
Wonder how long the telephone pole pieces would last if I put them parallel to the water flow and pretty much in the creek bed? They would sometimes have water flowing past them. Then I could put 2x12's on top for stringers.
   / Bridge Building #13
So how much life does a salvaged pole have left and don't forget about the wet environment next to a stream? I have no idea, but for a couple bucks, you could pour some nice concrete piers in sono tubes and have a much longer lived footing.
   / Bridge Building #14
If it was me, I'd probably just pile up a bunch of concrete sacks for a base and run some rebar through them into the ground below. Then lay treated lumber on the flat on top of the concrete with some rebar going through the board too. Leave a little sticking up so you can bend it over with a hammer once the concrete sets up. For the flat boards, I'd go with treated 2x6's or bigger. It's not that important how big the flat lumber is. Then lay your treated 2x10's on edge on top of the flat boards and attach them with metal brackets. Since you want it wide enough for an ATV, six feet should be about right. Two 2x10's glued and screwed together for your beams under the tires, and another 2x10 in the center. Start with that center 2x10, then go out two feet either way and put your doubled up 2x10s there. That is where the tires will be. Then deck it with treated 2x6's and screws. Never use nails on any exterior project.
A 4x4 will bend just from it's own weight over an 8 foot span.
   / Bridge Building #15
They also are pressure treated before they are set, and are checked and retreated periodically
   / Bridge Building #16
I was told with the new chemicals local power company will not teuse pole. Chemical leach from pole into soil for protection. If moved not enough chemical in pole
   / Bridge Building #17
Any footbridge or small vehicle bridge that I have seen around here has eventually washed out by a larger than expected rainfall. Even one the electric co-op built for a public park with big power poles to hold the bridge. Our creek bed is nearly the same size as the OP's, just a little larger, maybe 12 feet wide. With a 500 acre watershed, any bridge would be a major project, like public works would do for a road. I can cross with my walk behind brush mower by putting up a ramp on the steep side and going down a shallow slope on the other. No tractor access unless through the neighbor's property. I only have about a half acre on the other side of the creek, no it doesn't matter much, as it's all low lying.
It depends on the watershed the OP's creek has and the largest rain expected. Our 12 foot wide creek bed spills over and becomes probably 40 feet wide every two or three years.
I would say the OP has a good chance of a washout with that small bridge, unless the bed is very very deep under the bridge. It's not so much the water that destroys things. It's the debris. Our creek can carry 30 foot trees downstream and has recently rolled 300 pound rocks.
   / Bridge Building #18
I would also suggest to put in concrete foundations. It's not hard and it will eliminate problems down the road. My approach would be to pour an appropriate rectangular foundation under each end, perhaps 8 to 12 inches deep. Below that, dig several footing holes with a posthole digger, another 3 feet or more if possible. That will give an easy surface to build the bridge on and a treated wood structure on top of that will last many, many years.
   / Bridge Building
Washouts can always happen but I'm not too concerned here. I can literally step across the creek. I just don't want to drive the UTV up and down the bank turning it to a muddy mess. Just upstream, three feet maybe, is a woven wire field fence that would catch/slow most debris. The creek also just drains the hillside in my property. Maybe 10 acres or so. Dries up most summers. Really more of a fun project to do with my nephew than anything.
I've got a full size power "telephone" pole standing in my property. About three years ago the local EMC reran the power supply to my house when we renovated. They took all their equipment off the pole and I just left it standing for some future project. This may be it! Now I'm thinking I'll just put in two pole lengths as stringers and deck it over. Yes, the pole ends will be sitting in the dirt. If I get 5-10 years out of it I'll be happy. If it comes apart in two years, no biggie. And all material will be what I have on hand - zero out of pocket
   / Bridge Building #20
Standby; some day in the future you will kick your butt and say why did I not make this, higher, longer and heavier. Railroad ties make good stringers and sills. Have built several like that over the years. Could drive my 1 ton loades with gravel over it.
Ron
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A55788)
2017 Ford F-550...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
