majorwager
- Joined
- Oct 10, 2017
- Messages
- 1,062
- Location
- western new york
- Tractor
- kubota mx 5100 IH 484 ford 1620 lull 844b
Rarely agree w/ jeffy, but having mowed my 110 acres when transitioning from soy beans back to all grass hay, It is a laborious task w/ a 50 hp tractor using my 9ft. 2 inch mower.
Making an agreement w/ a neighbor to collect the hay would be a win/win situation. Warn against the advice to let it grow wild. Too many invasive species to take hold and other undesirable weeds would make the crop unusable.
Do you know what the composition is of the vegetation currently growing? If you do elect to perform the mowing yourself, a 2wd tractor would suffice , but likely impractical for any serious loader work. A 15 ft min batwing rotary mower would work, and the tractor hp. would be best in the 75 PTO hp range. You will find this investment expensive, even used, unless you possess adequate mechanical skills, used utility or row crop tractors can be maintenance intensive. The grass will go to seed late in the season, so you might escape w/ a single mowing. If I were to mow my fields again, it would be in my neighbor's 120 hp air-conditioned cab tractor and 20 ft batwing rotary mower, one of the tractors we currently use to cut and bale the hay..
I am accustomed to the CLEAN appearance of neatly mowed hayfields and there is still PLENTY of grass for wildlife. Actually most wildlife prefer to consume shorter grass, closer to the sugar core of the plant, and lesser concentration of deer flies. Best advice: some tasks that appear simple, possess hidden difficulties.
EDIT: Mowing calculator clearly applicable to turf grass only as the designer notes.
