New Kubota bx23s owner advice
   / New Kubota bx23s owner advice #1
thadri
Kubota bx23s
Hello all,
I am a new kubota bx23s owner and I am new to the forums as well. This is my first tractor and I finally decided to get one to help manage my rocky 5 acres here in Rhode Island. I am interested to hear any advice people want to give me on operating/maintaining the machine. Also, I plan to use it wisely and slowly and don't want to "push it" by asking it to do something it just can't. What is some of the best advice you can give me from any experienced owners out there?
   / New Kubota bx23s owner advice #2
You have a good attitude and ideas already. It’s a little tractor but it can do big jobs just a little at a time. As you use it you will get a feel for what and how much it can handle. Listen to the engine and transmission/hydraulics they will let you know when they are getting to the limit. Keep your fluids checked and overall get used to checking the tractor over prior to use. Keep it greased and after hard use let it cool down at idle for a short time, don’t just shut it off. It’s a great tractor and a big investment, take care of it and it will take care of you for many years
   / New Kubota bx23s owner advice #4
:welcome:
To the TBN forum Thadri. You have come to the right place to get answers.
Congrats on the new tractor.
thank you for the replies. I plan on learning as much as I can about the use of the tractor before I jump in the deep end. Hoping to learn any great tips from those who are much more experienced than me!:)
   / New Kubota bx23s owner advice #6
New BX23s owner also. First 2 additions to the machine, Bxpanded underarmor and their ripper tooth. I've had a compact tractor for 35 yrs the sub compact BX is awesome.
   / New Kubota bx23s owner advice #7
Check all your fluid levels before each day's work, especially during the first 50 hours. Top up as needed. Follow the maintenance schedule strictly, and don't skimp or cheat the first 50 hr service. Don't operate at full throttle for the first 50 hrs. Always operate your rig with safety in mind. Envision what you are about to do, before you do it. Start slowly, work up as necessary. Always be mindful of FEL & backhoe positions, and loads. Things can go wrong quickly with height & weight. Take some time & read the owners manual.
Enjoy your new rig, and what it can do for you!
   / New Kubota bx23s owner advice #8
Don’t hesitate to run your tractor at full throttle. Diesel engines and hydrostatic transmissions are made to run at the upper end of the RPM range AND at normal operating temperature. Dogging around in the middle of the RPM range is counterproductive and not conducive to long engine or transmission life.
   / New Kubota bx23s owner advice #9
Don稚 hesitate to run your tractor at full throttle. Diesel engines and hydrostatic transmissions are made to run at the upper end of the RPM range AND at normal operating temperature. Dogging around in the middle of the RPM range is counterproductive and not conducive to long engine or transmission life.
Perhaps you read a little too quickly the first time around: Don't operate at full throttle for the first 50 hrs. ;)
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
