log splitter conversion
   / log splitter conversion #1
Illcome
Sterling, MA
John Deere 4110 + John Deere LX280
I'm considering converting a Wallingstein WX310 (cylinder is 4''X 2''X 24'') by adding a motor, pump, and oil tank. Any advise on HP and GPM? Thanks
   / log splitter conversion #2
My suggestion is to only add a hydraulic tank, not install the motor but instead install a PTO pump. I converted my splitter to PTO pump a couple of years ago after my tractor hydraulic pump started to leak internally. Needed to install a new pump. I also changed out the 4" cylinder to a 5 " cylinder. I purchased the Prince 21 GPM PTO pump and a 15/17 gal hydraulic tank. I run the tractor at 1800 RPM, PTO at approx 390 RPM and GPM at approx 15. The 24 " stroke with the 5" cylinder cylinder gives about a 10 sec cycle time. Note the pump is a single stage gear pump so there is no ram speed loss per se. I have run the splitter in some 80 deg f weather, 3/4 hours and the highest oil temp was approx 105/110 deg f. HP for 15 GPM at 2250 psi = 19.6 HP. My auto cycle valve is factory set a 2000 PSI therefore I only need calculated 17.5 HP. Mounting the pumps reaction arm needs to be simple. Mine connects to the lower top link hole 3 pt. I needed to fabricate a right angle fitting for the suction side of the pump. Other than that it was and easy conversion. Without the pump and new cylinder cost I probably had roughly $900 in the conversion. Some pics. Later. 20151124_202852.jpg20151124_202951.jpg20151124_202904.jpg20150924_145442.jpg
   / log splitter conversion #3
Assuming they are all running the same pressure, the determining factor in engine size it the GPM rating of the pump you use with it.
I consider Timberwolf to be among the top brands of log splitters (they are also one of the few who give true tonnage ratings rather than the greatly exaggerated rating that seem to have become the industry standard). Their TW-2 HD splitter uses a 24"x4"x2" cylinder with a 16 GPM two-stage pump and a Honda GX 270 engine (270cc, approx 8.5 HP). They use a 15 gal hydraulic tank. They get a 9 second cycle time with that set-up and can drive a 4 way splitting wedge through all but the toughest logs (drop back to the single wedge for the really gnarly ones).
If you can live with longer cycle time, I see Honda GX200 engines (6 HP??) driving 13 GPM 2-stage pumps
and Honda GX160 engines (4.8 HP??) driving 11 GPM 2-stage pumps.
Personally, I would not have the patience to use an 11 GPM pump with a 4" cylinder. If I could swing it, I'd go with the GX270 and the 16 GPM pump or the GX200 with a 13 GPM pump.
   / log splitter conversion #4
It depends on how fast you want it to cycle and how much money you want to spend. An 11 gpm isn’t that bad for a 4” cylinder. I’d prefer more though. Picking a motor to fit your pump isn’t hard. Unless you can confirm that splitter was built to handle a 5” cylinder and downgraded to a 4” swapping cylinders is stupid.
   / log splitter conversion #5
For splitters you'd want to use pumps designed for splitter operation as they have special features that provide both speed and power, basically a dual setup with internal valving.
Fast when unloaded and a 'kickdown' when power is needed.
With that special pump a 5-6 HP engine will do the work of a 12 Hp and not require big tanks and coolers etc.
All commercial self powered splitters use those pump.
   / log splitter conversion #6
JohnM, PILOON and 4570man all have good advice. The only thing I will add is go as big as you can for speed. I run an 11hp HF Predator motor with a 22gpm two stage pump and wouldn't want anything else. My cylinder is 30"x4"x1.75". We cut most wood to 24"
   / log splitter conversion #7
I would try to sell the Wallingstein. Chances are you can just buy a small splitter from the box stores for less than what you'll have into converting the one you have once you figure in how much you could sell it for. If you do convert it I wouldn't change the cylinder. It was designed with that cylinder and ramping it up could bend things. I have a MTD splitter from Lowes that I've had for about 14 years now. It splits about 8 cords of wood a year and probably more like 14 for the first few years. The only issue I've had is the plastic spider between the lovejoy connectors between the engine and pump needed to be replaced (easy job).
   / log splitter conversion #8
Just for reference Timberwolf also makes PTO driven splitters.
   / log splitter conversion #9
Oldtimer 66
My unit is very similar to yours but it was built by a small commercial fabricator. My wedge is direct mount, no swivel joint,?
You have two spool valves? I have one, only hydraulic function is extend/retract ram.
My prince pto pump is smaller than the 21 gpm. I should research the model # but likey 11 gpm, reservoir is about 10 gal cap.
Never had overheating issue but I just built a hyd pto power unit capable of 31 gpm and that unit has a cooler w/ 12V fan. 51 gal reservoir.
A two speed pump would be nice, 5 inch cylinder retraction is kinda slow, but I am NOT a commercial producer so time not a big issue.
I prefer my vertical stroke, no interest in picking up large sections to set on a horizontal unit. Mine in 20 years old, works as well as the day it was purchased. Mounts right on 3 point and top link, Never hesitates, even splitting knots.
I have a non-contact tachometer but never checked pump rotation. Never needed the full gpm capacity, engine rpm at 1200- maybe 1500 tops. 540 rpm occurs at 2465.
Major difference between mine and yours is paint scheme, that would clash w/ ford blue.
EDIT:
It is ok to differ w/ opinion below. No one member's perspective carries any more weight than another. I prefer my approach and he appreciates his. Some like orange, others like green.
When the dust settles, the earth is still turning on its' axis, the sun still rises in the morning. All is good.
   / log splitter conversion #10
I’m not interested in sitting on a cut piece or bucket to use a vertical unit. A log lift isn’t that hard or expensive to build. I’ve had both types and a horizontal is way better.
Bucket (A55973)
Bucket (A55973)
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
Hydraulic spike driver (A56435)
Hydraulic spike...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
WARREN LIGHT TOWER (A58214)
WARREN LIGHT TOWER...
