GC2400 PTO spins slow - Any Ideas GC owners?
   / GC2400 PTO spins slow - Any Ideas GC owners? #1
reverton23
Warrenton, VA
Massey Ferguson GC2400
Hey there! Looking for some advice, before I take this tractor apart to get the transmission opened up.
I was using the tractor as normal, to cut grass with the MMM, when I hit a rock (last year Comcast dug a trench, which with all our rain has caused all these fist size rocks to rise up). Hitting the rock immediately caused the mower to stop working (blades stopped spinning). I turned the tractor off, and checked the the blades and deck, and saw nothing wrong. I started it back up, reengaged the mid-pto, with nothing happening. I removed the MMM, turned the tractor on, and engage the PTOs and saw that neither PTO shaft would spin at all. After a few hours I came back and tried again. This time the shaft spins, but VERY slowly. The rear-pto spins equally as slow.
Here is a link for a video of the shaft spinning, (and yes my hand reaching in and stopping it)
GC2400 Slow PTO - YouTube
as far as I can tell the linkage seems ok (that seems more like an on/off setup, it either engages or it doesn't)
I'd love to know what you all think it could be.
   / GC2400 PTO spins slow - Any Ideas GC owners? #2
I'm interested to see how this turns out, it sure doesn't sound good. I've always assumed/hoped that if I ever hit something big, any significant damage would be limited to the mower blades, spindle, or gear box.
   / GC2400 PTO spins slow - Any Ideas GC owners? #3
Throw out bearing maybe.. Any grinding at all? You’re hydro filter looks damaged, did you check your fluid level?
   / GC2400 PTO spins slow - Any Ideas GC owners? #4
Either you stripped a gear or rung out your pto clutch hub. Most things to do with this tractor are under the front transaxle cover. The cover is no fun to pull, but I've done a few and found that a wedge in the rh side frame rail can save lots of time. The big charge pump on the front has (4) 9/16 or 14mm head bolts and some O-rings behind it. Pay attention to these splines on this shaft and see if they are stripped or not. Also, check the notorious hydraulic pump on there too of course. If you see that these are ok, proceed to taking everything else out to get to the pto clutch. Disassemble and repair or replace the whole thing. Clean all contaminants out of the transaxle and put it all back together. Watch out for the detent spring and ball on the 4x4 lever. I wish you the best on your adventure through the innards of a gc.
Throw out bearing maybe.. Any grinding at all? Youæ±*e hydro filter looks damaged, did you check your fluid level?
No noises and engagement seems normal. When I disengage the PTO the shaft is slow to stop, but eventual it does. Fluid level is near the top of the site glass, probably a tad too much, but I can't imagine its causing this.
The filter has had a dent in it for awhile, but I'm not sure why. I need to pickup some new trans fluid, so I can drain it. I was going to do that see if there was any metal shavings that might come out... and a new filter too :)
Thanks!
This is great info! I was thinking I might be able to open the cover and possibly pull it off and get a look inside to see what might be going on, so the wedge info is great idea... pretty sure I'll figure out exactly where a wedge needs to be put once I get started :) If I can get a good look inside I'll feel a lot better about ordering what I think it needs.
*I promise I didn't intentionally leave this out, but a couple months before this happened, I had some grinding when I would engage the PTO's. I figured it was the clutch, but after a few more times of using it it went away, and was fine. like I said that was 2 months before this happened.
It's been a pain to get parts - dealer isn't close, and won't drop ship. Some of my past orders took 2+ weeks to get; so the idea of opening it and waiting that long for parts isn't great, but then again so is special ordering what I think it needs, and finding out its something else. Just trying to narrow it down.
Everything else on the tractor works great, including the front end loader, so I've assumed the hydraulic pump is ok, but I will check everything over.
   / GC2400 PTO spins slow - Any Ideas GC owners? #7
Double check the splines on that front charge pump though for sure. I've seen strange things happen in this area. Know what your serial is because these tractors do have several serial breaks. Double check part numbers. My dealer drop ships and you can call Herrington Equipment. 843 889 2248
Thanks so much! Hoping to have an update for everyone next week.
   / GC2400 PTO spins slow - Any Ideas GC owners? #9
Pull the screen as well when you change your fluid and filter and clean in with brake clean.. I don't think it's your problem though..
   / GC2400 PTO spins slow - Any Ideas GC owners? #10
I would also investigate why shear pins on the mower didnt let go first.
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
