150 Sq. Ft. Cabin Build. Help with solar ideas.
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #1
CoachEarl
Member
Falls City
Mahindra 2538 HST
We are converting a 10x15 shed into a hunting cabin at the ranch. I live in South Texas, so cooling will be a must and I'm assuming I will have to run a window unit from the generator. Any ideas on a inexpensive solar system to run some LED light and a couple of plugs to charge phones over night? I also want to find a way to be able to add battery charge while using the generator if that is possible. Solar experts, help me out!
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #2
HF has a 'cheap' 100W system with 4 25W panels, a couple of lights and a controller. You'll need batteries which they sell for another $70 each for a 35Ah SLA.
I've seen other systems available on the various marketplace sites that use 100W panels and include a controller and cables. Panels can be linked together for more capability, but they're larger and will take up more roof or ground space. Again batteries are separate and can get very expensive for the deep cycle type needed for solar systems
If you only want to run a couple of small lights, you may only need to use 2 or 3 batteries to hold the charge to get through the night. You will NOT be able to run anything on AC utility type power without an inverter and that gets into a lot more money and the need for more or larger batteries.
One other thing to look at is a wind turbine in you're in an area with sufficient wind. You'll still need the other components such as controller, inverter, batteries, etc.
I have a lot to figure out and learn to make this happen. Thank you for the information. Going to be a fun project.
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #4
That will be a fun project to watch you build, so please keep us posted. I'm very interested in solar, but from what I've read it takes a pretty large system to run A/C. You could run fans though. I have read about some innovative cooling systems:
Cooling Device Made from 2 Liter Bottles Uses Zero Energy
Also, in a hot, dry climate, you can use an evaporative cooling system (they don't work in humid conditions). You can buy evap cooling units, but people have made them too.
I take it there's no way to get electric to the shed?
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #5
You need to do the math starting with what you will be using. If it's four lights, and they all use 5 watts each, for a total of 20 watts, you need to size the system to handle that amount of energy. If you add more things to it, you have to increase the size of your cellls and batteries.
Or you could just go RV on it and look at what some of the RV or boating companies have out there. They sell everything for 12 volts, which makes using automotive batteries practical. Figure on buying a couple of batteries and a solar panel to keep them charged during the day. You can get a 12 volt coffee pot once it's installed.
Or you could just buy a small Honda generator and use that to power everything while you are there. They sip gas, run forever and they are super quiet. Keep it simple and in the long run, it will be cheaper.
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #6
OP implied using a generator for the air conditioner, so I really didn't go into that too much. I don't know how much cooling would be needed after dark or if they use it year round when cooling may not be needed.
South Texas. It has been over 100 for some time here now. It will not actually cool off until November, so when out there will use it a lot.
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #8
If you're going out and back by vehicle daily, it may be just as easy and cost effective to carry a 5 gallon gas can and a small generator. Only problem I see there is the noise chasing critters off. Since it's a hunting cabin, that may not be what you want to do.
If you're staying overnight and only need limited lighting and no cooling, then Solar or Wind may be worth the cost.
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #9
Look up Backwoods Solar on the net. You can get a small charge controller to connect both solar panels and generator. Batteries will charge on whichever source is available and will protect the batteries from overcharging. Regarding A/C, I built a swamp cooler out of a 5 gal bucket using a 12 volt fan. Works good for my 5th Wheel as long as the humidity is low. I'm afraid South Texas will not work. Look up Burning Man and air conditioning for ideas.
   / 150 Sq. Ft. Cabin Build. Help with solar ideas. #10
We have a cabin and looked into every possible angle to power it. Solar is nice, but it's high maintence and almost requires a full time occupant to make sure everything is working ok. To have a decent system, your looking at around $15K.
We went with a diesel generator. It can run 24/7 and you can build an enclosure to store fuel and deal with noise. I can put 5 gallons in it and it will run all my needs for a weekend.
Until they harness fusion power, fossil fuels are still your best way to generate power. Plain and simple.
This is what you need...
2018 JLG 3246ES 32ft Electric Scissor Lift (A55787)
2018 JLG 3246ES...
2013 CAT 246C (A47477)
BUNDLE OF 96" X 40" DIAMOND PLATE SHEET METAL (A54756)
BUNDLE OF 96" X...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
Year: 2000 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 120,822 Plate: Body Type: 4 (A55852)
Year: 2000 Make...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
