Stupid question but...How often do you replace blade bolts on rotary cutter..??
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
Tomorrow I'm pulling and sharpening the blades on my old Deere 503 rotary mower.
Not sure how old it is since I purchased it used years ago but I'd say it 30ish years old and I'm going to assume the blade bolts are original.
I searched the net and couldn't find any recommendations on how often to replace the bolts. Maybe there isn't a useful lifespan and they are to be reused until failure.
What says the experts..???
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #2
If the bolts are not damaged or the blade holes are not wrung out, I see no need to replace them.
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #3
Agree on not replacing bolts unless damaged. However, always replace those self locking bolts a lot of them have or put a castellated nut on instead, You then need to drill the bolt for a cotter pin. Once used self lockers that feature is defeated. Biggest problem is getting the **** things off to begin with. I have had to cut them off.
Ron
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #4
At failure, the blade is traveling x feet per second. You want to catch a 10-20 pound chunk of steel ? I replaced the blade & bolts of my 22 year old Bush hog. I did destroy one of the bolts getting it off. So I was glad I already had replacements, instead of making a second 60 mile trip.:2cents:
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #5
Short answer...never. Those giant shoulder bolts would have to be nearly worn 25% or more to be a failure risk. The bolts on my King Kutter still look nearly new after 30 years of hard use. Remember, they don't pivot continuously while in use, they only pivot at startup, shutdown, or if you strike something really hard.
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #6
This is a pic of the old and new blades for/from my 5' Woods Cutter.
My guess is they are original, I bought it (very) used.
My unit has large pins with special locks for the blades that were still good.
An old tractor Dude told me that you never sharpen them to a point, if you do then they chip.
My old blades have eaten numerous pieces of concrete rubble and were still cutting good.
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #7
Glad people ask questions like this.
I pulled and sharpened my blades this evening after work. The bolts and blades looked fine. The blades were easy to remove with the assistance of an air hammer. I used my DeWalt 20 volt angle grinder to sharpen the blades. I mowed a road leading to a food plot and its cutting great.
   / Stupid question but...How often do you replace blade bolts on rotary cutter..?? #9
This has been discussed before, but you really shouldn't sharpen your blades to razor sharp if you are cutting fields.
What is the logic behind running dull blades..??
I didn't get them anywhere near razor sharp but I put a decent edge on them.
MISC PALLET (A55745)
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
