I thought that only happened in cartoons
   / I thought that only happened in cartoons #21
Huh? Scented sun what?
So those things were an artillery shell, and not some anti personel device? And the fuse would be lit separately and not explode on impact?
   / I thought that only happened in cartoons #23
My guess is it was what we used to call a qtr stick. Larger homemade version of an M80.
According to a local news source, that is exactly what it was. Not home made, but a commercial firework called "quarter stick" of dynamite. And I can tell you from experience, although they are powerful, they are not equal to the explosive force of what a quarter stick of real dynamite would pack.
   / I thought that only happened in cartoons #24
Life is often a Cartoon!
   / I thought that only happened in cartoons #25
Only 'dynamite' that I have seen or know of is actually Forcite and is putty like wrapped in wax paper.
For sure not anything near a candle.
Also electric blasting caps are the norm, not fuse wicks, but guess they still exist.
My brother found a stick in an old shed back in the 50s. set it on a stump and lit it. Fact. Dynamite will burn but not explode unless a shock (blasting cap) is used to set it off...at leasst in the formulas used in the stuff anyone could buy in hte hardware store back then. We used it blasting stumps.
   / I thought that only happened in cartoons #26
Dynamite would also come in different percentage strengths for what you needed; 40% was pretty much what you used for stump work as you just wanted to loosen them so they could be dozed out. 70-75% was used for shattering rock, and if you'd use that on stumps you might wind up with a kindling mess.
   / I thought that only happened in cartoons #27
We were blowing up some friend's model ships with small firecrackers in the yard one summer day. My father came out and watched. The models would bounce a bit, but not much damage. Dad was, among many things, a demolitions officer in a combat engineering battalion in WWII. He showed us how to pack some dirt around the firecracker and put a large rock next to it to direct the force of the explosion into the model..... WOW! It split the boat in half! That ship was SUNK!!! THANKS, DAD!!!! :laughing:
   / I thought that only happened in cartoons #28
We would drill a hole in a small juice can(one end is cut out) that would hold a Blackcat tightly. Place small can in a slightly larger can with a couple inches of water in the bottom. Light fuse and BAM! Small can shoots up about 100 feet. Great Fun for a kid.
   / I thought that only happened in cartoons #29
Yep, probably an M80 or Silver Salute or something similar. That I can believe. The 1/4 stick of dynamite I DO NOT believe.
Don't get me wrong an old M80 will easily blow off fingers. It ain't anything to sneeze at and could be very dangerous in ignorant hands.
   / I thought that only happened in cartoons #30
The man obviously knew the advantages of a "shaped charge".
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
LOT LOCATIONS (A52576)
2016 FREIGHTLINER CASCADIA DAY CAB (A52576)
2016 FREIGHTLINER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
