to flux or not to flux?
   / to flux or not to flux? #1
W8BYA
Ossian, Indiana
NH Boomer 40
I love to stick weld (use an old AC buzz box) and use oxi-acetylene as well but have been thinking of getting a MIG welder. I did some MIG using external Argon tanks MANY years ago when in HS when I first learned how to weld and have wondered from those who have tried both if the gasless MIG's that use coated flux wire work as well as "bare" wire and a stream of gas? Pro's Cons, etc, etc Tnx !
   / to flux or not to flux? #2
As a beginner with only some welding in school I found flux core harder to use and the welds not nearly as good as mig. Maybe someone with lots of stick experience could do better with flux core. Flux core wire is more expensive than mig wire so that eats up some of the cost savings vs mig. Other than the cost of gas I don't see a downside to mig.
Thanks Eric I appreciate your experiences with both. My main interest is to weld better in other than flat-down or mostly horizontal type welding or thinner metals.
My vertical up's & down's etc suck LOL. Horizontal welding I can do well enough and I know with some proper training & experience (and proper choice of rod) I could do much better.....it's just so darn easy & fast to weld in almost any position with MIG. It would be nice to have a "MIG" welder w/o having to maintain another huge tank of gas if the flux coated wire works as well.
   / to flux or not to flux? #4
I have a Hobart Handler 140, but sort of immaterial to my response....
Started out with fluxcore (FCAW) and when demo roll was used up I went and got a full roll (2 lb.) of fluxcore....Somewhere along the way I decided to hook up a cylinder of C25 and switch to solid wire and shield gas (GMAW).... About 10 small rolls (2 lb.) of solid wire later I have never gone back to fluxcore...
I love GMAW.... Point here is if going MIG get a machine that will do both because there is actually some situations where FCAW actually is better (really dirty material or in slight breeze), but all my work lately has been all GMAW....
I also find out of for position MIG is better for me than I was ever with stick...
Good site to answer questions inquiring minds want to know...
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Also if you get a MIG machine some manufacturers have forums for internation with other elders with dam brand products and with hteir tech support people....
Hobart site....
Forums -
Weld Talk Message Boards
Dale
Started out with fluxcore (FCAW) and when demo roll was used up I went and got a full roll of fluxcore....Somewhere along the way I decided to hook up a cylinder of C25 and switch to solid wire and shield gas (GMAW).... About 10 small rolls ( 2 lb.) of solid wire later I have never gone back to fluxcore...
I love GMAW.... Point here is if going MIG get a machine that will do both because the is actually some situations where FCAW actually is better(really dirty material or in slight breeze), but all my work lately has been all GMAW....
Dale
Hiya Dale and thank you for the great info & advice. Ehhhh, got 2 big tanks already what's one more? <g>.
Somewhat off topic from my original post but am wondering if you think MIG can be used for steel up to say 3/8" thickness? That is about the thickest metal I can see myself welding, like when I just welded on hooks to this 3/8" plate steel. If so what current rating machine & wire diameter would be appropriate or needed?
   / to flux or not to flux? #6
There is no" single best" process,but there are best processes for various jobs,skill level,expense and any number of other considerations. If majority of projects are 1/8" or less,gas shielded is a good choice. On the other hand many homeowner machines handle either process but will weld thicker running flux core. Then of course there's the question of welding outdoors where flux core get's the nod.
   / to flux or not to flux? #7
Definitely. The gas cover can be blown away by a breeze and play havoc with the weld.
   / to flux or not to flux? #8
MIG pros > easier to learn, nicer looking welds, less slag
MIG cons > not good outdoors when windy, have to refill tanks
Flux Core pros > no gas to refill, better for vertical welds
Flux Core cons > more slag, welds not as smooth looking
I stopped using MIG when the large corporation gas refillers bought out out the local guys. That, and regulations made it hard to refill. In my case a local refiller exchanged my personally owned (new) tank with a filled older tank, promising to keep track of it. They sold to large corp and "my" tank was forever gone. Then, after inheriting a large tank from my FIL, no company would refill it without testing and recerts - FIL had no such issues.
Wow you just hit on a couple of very, very interesting points. The 1st was when you said "Flux Core pros > no gas to refill, better for vertical welds". I would have guessed no flux and gas would be best for clean deep vertical welds.
But what you said later REALLY got my attention. About 12 years ago I purchased my own tanks from a large supplier in Ft Wayne. Anytime I needed them refilled the owner (who remembered me) would simply document the tank numbers and give me a different pair of tanks that were mine to own also. What has me petrified is when they go dry and I need to refill them because he sold out to a super large nationwide supplier who when I called said they purged all prior records etc. I think they just bought the ole guy out to eliminate competition. So now I fear I may not be able to get my 2 tanks refilled :-(
   / to flux or not to flux? #10
No one I know of around here fills tanks on their premises. You take in your empty and they give you a filled one. You will probably never see your original tank again. The empties are then sent to a central facility for refilling. At that point re-cert and valve replacements are done. I just had to pay a re-cert on an old O2 tank I bought at the auction. Way the business works. Luck of the draw when you get a tank that needs re-cert or you have it a long time (10 years I believe).
Ron
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
Zero Turn Mower (A59231)
Zero Turn Mower...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
3410 (A47477)
3410 (A47477)
