Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,521
Just curious, wouldn't these harbor freight dollys work? I have four and a heavy car rolls easily on them. They're not expensive and hold 1000# each.View attachment 583144
I was using furniture dollys and I couldn't get it to work. Messes up the geometry coming off, at the very least. Maybe if I put the tractor on boards to lift it to compensate.....I'm not sure. I gave up after like 3 years of trying.
   / Pictures of your snow weapons #4,522
I was thinking those just to move it around.
A properly mounted electric winch in ceiling I have here and it's handy for lifting things. Just throwing out ideas.
   / Pictures of your snow weapons #4,523
Probably true, but this was easy and free. Result is the same, it is where it needs to be. I need more room for my implements, regardless. Maybe someday...(as if)
   / Pictures of your snow weapons #4,524
   / Pictures of your snow weapons #4,525
kjudd
The 2610 is ready for another winter.
Let's hope old man winter vacation else where this winter. ;)
   / Pictures of your snow weapons #4,526
kjudd
Can you tell us about the "cab" ? New addition this year?
   / Pictures of your snow weapons #4,527
Took off loader installed snow blower. Little beast spending winter outside because the wet year turned the shed and yard in to a mud pit.
Linear actuator for chute failed. repaired it last year. replaced it this year. Added an inline connector so easier to replace in future.
   / Pictures of your snow weapons #4,528
Probably work OK. Problem is that the wheels are a bit small. Any little pebble in the way and the wheel will not roll. I made a Dolley for my 'full Dress' motorcycle. It had Dual 3" wheels in each corner. The tiniest pebble would stall it. But I needed it that low to get that beast up on the Centerstand. I have made dolleys for Cat 1 hitch Rototillers and Rakes to do just what you are saying. I have a welder so it's easy. A pleasure to drop the Tiller on the dolley and just roll it deeper int the garage and rotate it into the corner.
These car moving dolleys may get you started but I would think you need 4. two under the bucket and one under each Leg. For stability you may want to find a way to join all 4 together so they roll as a unit.
   / Pictures of your snow weapons #4,529
If we ever get snow this year, I could actually try out the new snow weapons.........:(
   / Pictures of your snow weapons #4,530
kjudd
It's a $60 golf cart "cab". Works great i just put it on for the winter this is the second winter for it. The front windshield is kind of hard to see out of during the daylight from being wrinkly but at night its not a problem. But im putting a plexiglass frot window in for this winter. For 90 bucks total I can't complain.
2011 John Deere Tractor (A55973)
2011 John Deere...
17101 (A55787)
17101 (A55787)
PALLET OF MISC PUMPS (A54757)
PALLET OF MISC...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
KOMATSU PC170LC EXCAVTOR (A52707)
KOMATSU PC170LC...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
