I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #1
drizler
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #2
It's up to $38.99 here and never on sale. When I started using it they were charging 32 and occasionally on sale for 27. It is still the lowest price oil on the market that meets the needs of modern tractors.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #3
$39.99 at my local store.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #4
Meets the spec, doesn't mean it's as good.
The basic oil is all about the same, the difference is the additives.
You should weigh all your options; this isn't a good place to save a few bucks.
There are also synthetic, and semi synthetic options now, which can last longer, and work better in extreme temperatures.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #5
Thanks Ray, good advice.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #6
There are many places to save a few bucks but hydro fluid imo is not one of them. Here's why. Agco 821xl fluid is sold in three ways non-synthetic, blend synthetic, and full synthetic.
Nextvrecognize that hydrofluid should get changed every 200 or every 250 hours per manuals and model. That's a lot of hours for a quality product to do "its thing". And each spring virtually every dealer has a spring customer appreciation days with discounts on parts (which includes filters and fluid). Last year i bought 5 gal full synthetic agco 821 xl for 75.00 and i could have bought semi synth for 67 .00. I wouldn't use less than semi synthetic for Wisconsin weather.
My point is non-synthetic tractor supple hydro fluid is only 20.00 a 5 gal pail cheaper and only 30.00 less than semi synthetis. It isn't worth it over a 200+ hour timeframe imo. Also, on the parts sale the hydro filter is less than 30.00. So i keep extra items on the shelf.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #7
Just bought 2 pails. 39.99 each.
Printed on the pails is that it meets xl821 spec, permatran III, and other massey specs. Works for me.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #8
If it meets the Specs., it's good enough for the equipment that requires those Specs.
If a machine needed semi or full synthetic oil, the manufacturers of their machines would specify that in the Owner's Manuals and ship their tractors with the same. Regardless, I always change my oil and filters at the intervals that equipment manufacturers specify.
That's the way I see it. But like always, "To each, their own."
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #9
Those that say saving on fluid is not important have not owned a machine with a 28 gallon capacity. Just saying.
   / I Seee Tractor Supply Has Travellers Permetran/ 821 Equivalent On Sale $40 #10
Or have not ripped off a hydraulic line in the woods and had 8 relatively new gallons spill out 👍🏻
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2007 GREAT DANE CONVERTER DOLLY (A51222)
2007 GREAT DANE...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2002 International 9200i Truck (A52128)
2002 International...
