New to me drill press repairs
   / New to me drill press repairs #11
Crack goes from edge to edge so nothing to drill, it will get beveled. Going back and forth on brazing or using nickel rod. Based on my buddy that does this type of work all the time I'm leaning towards using ni55 rod, plus he already has some I can use :)
Got it appart, now it's time to clean it up and grove it out with a carbide burr.View attachment 587348View attachment 587349
I do that weld with a single pass of nickle rod without thinking twice.
   / New to me drill press repairs #12
I'd vote Ni99 if you want to stick it. Or Hot Spray Powder. Or Tig or Braze with Ni Ag. Much nicer than Bronze. Easy fix.
Why do you suggest Ni99? this is a decent size casting and will need some cleanup/machine work possibly. Spray powder isnt really the right process for this repair, it has structure, not just closing up an exhaust manifold or head crack.
I think I'll be going with the Ni55 for this one.
   / New to me drill press repairs #14
the whole point is using something that can stretch, else the weld will crack on cast iron unless the part is heated in an oven first, and then put into an oven and allowed to cool slowly. without the oven, either bronze or Austenitic stainless steel is recommended, with the Austenitic stainless steel giving a stronger weld..
   / New to me drill press repairs #15
Brazing, if done correctly, will be the strongest repair. The nickel rod would work OK too as long as the cast is of decent quality. It won't be as strong, but likely be fine.
Pre and post heat are given, I have a decent size oven capable of 2400*f so no problems there.
I've done repairs on cast using stainless and brazing, not much using Ni rods, looking at the casting and application guides the Ni55 seems to be the best fit for this repair.
   / New to me drill press repairs #17
Or you could just give up. I would came haul away the scrap for you. :rolleyes:
I've got some crap..... I mean scrap you can have
   / New to me drill press repairs #19
2023 Bintelli Beyond Golf Cart (A51573)
2023 Bintelli...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
