Rock Crawler
- Joined
- Aug 15, 2017
- Messages
- 2,227
- Location
- Pittsburgh, Pa.
- Tractor
- 2021 Kubota L3560 HSTC, 2011 Craftsman Excellerator GT (680hrs), 2018 Husqvarna TS354XD, 2017 Husqvarna HU800AWD, 2019 Kawasaki Mule Pro DX (Yanmar)
I was just thinking, I change the engine oil/filter and grease fittings religiously. But I kind of ignore the gear oil in the PTO driven gear boxes on my rotary and finish mower. Is there a "typical" amount of years or use that you personally apply as a preventative maintenance plan for your PTO driven gear boxes? I would guess that my use is around 30-40 hours per year, and gear lube doesn't see combustion process contamination. I guess that it also does not see much by way of cooling and it sees nothing at all by way of filtration.
So please share with me your personal opinion on maintaining the gear box lube, and if you have any relevant operational experience of service related failure (lack of maintenance) I would appreciate hearing that as well.
I just wonder, if you bought a mower and ran it for a decade... or two.... would it just keep slinging grass with little to no fluid changes or is it imperative that you replace the lube more often than every year or two?
Full disclosure: I am new to the PTO driven mower scene. I am on year 2 with my "new to me" rotary rough cut mower and year one with my "new to me" finish mower. Both are likely 10-15 years old, and I have not changed gear box fluid yet, and have no clue if anyone else had ever done so.
