3-Point stuck UP !
   / 3-Point stuck UP ! #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
I walked out to the Tractor this AM, was going to hook up the Grader/Planer and run over the road.
As I approached the tractor I noticed I must have forgotten to lower the 3-Point last night, no biggy, I push the lever to lower it, without the engine running and nothing happened. The Brush Cutter didn't go down ?!?!?!? Puzzeled !
I started the tractor, but nothing changed; before I start tearing apart my Max28, is there anything I should know, a safety Valve maybe, a lever I didn't know about... hoping for something little.
Thanks for any assist !
   / 3-Point stuck UP ! #2
Did you put Viagra in the fuel last night?
On a serious note: Did you try to raise then lower (engine running)?
   / 3-Point stuck UP ! #3
Did you check the drop rate valve? usually in front of the seat...?
   / 3-Point stuck UP ! #5
   / 3-Point stuck UP ! #6
So do you have to wait up to the 4 hours? :)
   / 3-Point stuck UP ! #7
Oh, and I forgot to mention: the WHY? did the valve get turned in the first place? You accidently turned it with your foot getting on or off of the tractor.
I put some Viagra in the fuel tank, hoping to get the little Tractor to have little more push... that didn't help !
Yes raising and lowering the lever was the first reaction. Engine running and not running.
I tried to move the valve but to tell the truth not sure if the tractor was running or not. I will attempt again today.
I know this link is for a Kubota, but this might be the issue as pointed out in previous post
The most MISUNDERSTOOD control on a tractor - TMT - YouTube
I watched the Video, I will try again this AM.
I got one caught in my throat and had a stiff neck all day... LoL !
Also, is your Handle (K0UA) a Ham call sign... ?
Thanks for all of the suggestions,I need to get it working today, got to get the Grader/Planer going !
   / 3-Point stuck UP ! #9
Yes, I am KØUA.. you can look me up on QRZ
   / 3-Point stuck UP ! #10
For me it is when I turn to look behind me to back up. :D
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
