2040s 1986 contaminated hydraulic oil , no brakes anybody help
   / 2040s 1986 contaminated hydraulic oil , no brakes anybody help #1
Dogsbreath
John Deere 2040s
Grease contamination in hydraulic oil ,no brakes
Grease nipple above where you put his oil in tried pumping grease in there blocked changes nipple pumped grease in not good no brakes , anybody any ideas
   / 2040s 1986 contaminated hydraulic oil , no brakes anybody help #2
You just pumped the brake piston chamber full of grease. The fitting you removed was a bleeder, not a grease zerk.
   / 2040s 1986 contaminated hydraulic oil , no brakes anybody help #3
Welcome to TBN
I'll suggest to attempt to bleed brakes similar to bleeding auto brakes. One needs to have engine running while bleeding procedure is performed so trans pump can keep brake reservoir replenished with hyd oil.
You just pumped the brake piston chamber full of grease. The fitting you removed was a bleeder, not a grease zerk.[/would that have contaminated the hydraulic system .
   / 2040s 1986 contaminated hydraulic oil , no brakes anybody help #5
I am with TxJim, try and push the grease out by bleeding the brakes. If you do not want to run the tractor while bleeding the brakes, you can remove plug 5 and fill after about ten pedal pushes. Also do not allow the pedal to "snap back" or you could damage the brake valve.
Any idea how much grease was pumped in?
Over time, I think the grease that does not come out by bleeding the brakes will dissolve, after all grease is used to hold packings and o rings in place during assembly.
About half a cup full of grease gone in bleeders ,would changeing hydraulic oil and filter do the job
   / 2040s 1986 contaminated hydraulic oil , no brakes anybody help #7
What part in the schematic is the bleeder?
   / 2040s 1986 contaminated hydraulic oil , no brakes anybody help #8
Bleed them thoroughly first. Your contamination may be from other sources as well. Get as much of that grease out as you can then dump the oil and change the filter.
Thanks for that will try bleeding the brakes​
1067 (A53342)
1067 (A53342)
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
(3) BRUSH GUARDS FOR TRUCK (A51248)
(3) BRUSH GUARDS...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2018 Mac 48FT. T/A Walking Floor Trailer (A51692)
2018 Mac 48FT. T/A...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
