Capless fuel tanks... is the idea as dumb as it seems?
   / Capless fuel tanks... is the idea as dumb as it seems? #11
My Ford came capless. A quick trip to Autozone and 10 bucks later, I had a locking cap. I don't care for the capless crap either.
   / Capless fuel tanks... is the idea as dumb as it seems? #12
My pickup that came capless would have had considerable dust in the filler neck and I have to believe that much of that would have made it past the second flap and into the tank.
With dirt roads, fields and field roads it sees considerable dust. I actually rinse out the fuel fill area when ever I add DEF to the truck as usually a little bit slops and I routinely rinse it after filling. To me having an uncapped fill port is just asking for dirt and garbage to have access to the tank.
   / Capless fuel tanks... is the idea as dumb as it seems? #14
Because the extra 10 seconds it takes to remove the cap is too long to wait?
   / Capless fuel tanks... is the idea as dumb as it seems? #15
The biggest problem with the capless filler is when people try to add fuel from a can or fuel additives. These vehicles need the adapter/funnel that gets the fuel/additive down past the 2nd check valve. If you don't, you may damage the evac system and you will get a check engine light. If you are adding sta-bil, heet, octane booster, or other additives, read the manual. You may have the adapter stored near the spare tire or you may have to get one from the dealer.
   / Capless fuel tanks... is the idea as dumb as it seems? #16
Well - - Schazbutt - the Taco Wagon came with a screw in cap on a tether. It also has a manual activated 4WD shift lever. Some of the old ways are still better.
   / Capless fuel tanks... is the idea as dumb as it seems? #17
2014 Ford Focus capless, I live on dusty gravel roads, 92,000 miles and no problems.
   / Capless fuel tanks... is the idea as dumb as it seems? #18
I’m going on 5 years with my Ram 3500 and no fuel cap. Fuel filters come out clean as a whistle every 15K miles. I was concerned early on, not so much now.
   / Capless fuel tanks... is the idea as dumb as it seems? #19
No way to add a locking cap to any of the newest Ford trucks that I know of. Lots of discussion on the Ford forums about that and apparently no one makes anything that will fit. I'd love to have one - I drive a lot of dirt roads and have to make sure I blow the dust away from the fill each time I gas up.
If you've found something that works on the new trucks, share that information!
   / Capless fuel tanks... is the idea as dumb as it seems? #20
My 2013 F150 is capless. I was very skeptical when I got it, but even it the dirt, dust, etc, the outer door seals 100% and keeps the inside area spotless. Much cleaner than the old style doors with caps inside. I'm completely sold on them and spoiled. Nothing worse that trying to fuel the old style vehicles with caps when I jamb the fuel nozzle into the cap that's still screwed in place. :D
JLG 20MVL MANLIFT (A58216)
JLG 20MVL MANLIFT...
2001 MACK RD688S WATER TRUCK (A58214)
2001 MACK RD688S...
2018 Kubota U17 (A53317)
2018 Kubota U17...
1989 CAT D30D Articulating Dump Truck (A59213)
1989 CAT D30D...
2018 Ford Transit 250 (A57148)
2018 Ford Transit...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
