How much horse power(vehicle) needed to pull 1000 tons weight trailer?
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #1
Aung Thu
I need to move 1000 tons weight stone about 300 km. And I want to know how much horse power(vehicle) needed to pull 1000 tons weight trailer? And also need to calculate it?
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #2
1000 tons = 2,000,000 pounds:eek:
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #3
im assuming metric tons. that's 2.2 million lbs. just for the record.
it would require at least 3 semi trucks, and a massive trailer with 20 or more axles in the states.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #4
Some places call a ton (metric ton) 2200 lbs.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #5
Something is missing here. You are asking how much horsepower to move 2000000 lbs. You need to go talk to a heavy hauling trucking company. I hope the stone is worth moving!
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #6
If this big stone is being move down a hill, you need more brakes than HP!
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #7
I hope this is a joke.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #8
Sounds like a school homework question.
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #9
The simple answer is, "enough".
The question in my mind is, are you moving one stone that weighs 1,000 tons or many stones that total up to 1,000 tons?
   / How much horse power(vehicle) needed to pull 1000 tons weight trailer? #10
you'd probably have to try to rent this. The Crawlers | NASA even a mining truck could only carry less than half 1,000 tons. even then, try to get one of those on a road!!..
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Kubota RTV-XG850 Sidekick (A56435)
2023 Kubota...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
JOHN DEERE 6615D MFWD TRACTOR (A52708)
JOHN DEERE 6615D...
