motorhead3
- Joined
- Apr 10, 2019
- Messages
- 6
- Tractor
- Kubota BX23S
Bought one of those hydraulic pressure gauges with a shim kit. My less than 100 hr BX23S was reading 1750PSIG so I was going to add the 0.2 mm shim to bring it up 80PSI more. Took off the cap, installed it and retest showed 2500PSIG. Tried it with the stock shims and still 2500PSIG. Took out all shims and got it to go down to 2300PSIG so the relief is functioning. Checked the gauge, its good. Everything inside the relief moves easily,spring ,poppet, except the relief valve seat. Won't budge. I ordered a new one to see what I'm up against. Didn't get it yet. The original must of moved when I first disassembled it and I drove it in to far or cocked when re tightening it, their are holes on the side of the seat cage that don't exactly alien with the drain hole in the casting. First is 2300PSIG to much for this tractor? Maybe the spring is to tight and the cap just wasn't that tight from the factory. File the spring? I have no clue how to get the seat out other then try to thread a bolt into it and pull, or carefully drilling it out, thus destroying it. I'd appreciate any advise because I'm very meticulous they way I take care of my equipment,boats, cars, etc, and this is kind of embarrassing.
