how to add air to tractor rear tires with ballast
   / how to add air to tractor rear tires with ballast #1
bfknouse
Medford,NJ
Ferguson F40
I have a Massy F40 with rear tires that have ballast what is the correct way to add air?
   / how to add air to tractor rear tires with ballast #2
Its easier to do when the valves are at the 12 o’clock position.
   / how to add air to tractor rear tires with ballast #4
^^^^^This. You may get a little wet but it won't take much air at all since most of the tire is filled with ballast and you can't compress it.
   / how to add air to tractor rear tires with ballast #5
I had my tires filled and tried to check the pressure. Even with the valve stem at 12 0'clock I got wet. It turns out one tire was over filled. I simply took the hose off a hand pump, attached it to the valve stem and drained about a gallon of fluid into a pail. Now both tires can be checked and adjusted 'dry'. I leave the gallon in my unheated garage in a container and shake it on cold winter days to see if it is getting slushy. Also, I used a cheap pressure gauge that first time - glad I did not fill my digital gauge with antifreeze.
   / how to add air to tractor rear tires with ballast #6
Either use an air gauge that can take water or use the Harbor Freight one that I like that has a long extension on it with built in gauge. Just blow any moisture out when finished.
Ralph
   / how to add air to tractor rear tires with ballast #7
Some say to give the tire valve a blast of air to clear it of juice before using a tire gauge so that gauge doesn't get contaminated.
   / how to add air to tractor rear tires with ballast #8
Everyone, thanks for the tips as I have been sprayed with "beet juice" a few times (pretty sticky).
Does it help any to jack up the tire off of the ground or is that a waste of time and effort?
KC
Thanks it worked
72in Boom Lift Basket (A56857)
72in Boom Lift...
John Deere Tractor Weights (A57149)
John Deere Tractor...
UNUSED FUTURE TR47 FORKLIFT TELESCOPIC BOOM (A58376)
UNUSED FUTURE TR47...
2008 CAT D6T DOZER (A58216)
2008 CAT D6T DOZER...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
EZ-GO Freedom RXV Electric Golf Cart (A57149)
EZ-GO Freedom RXV...
