Battery based electric vehicles of today and tomorrow.
Status
Not open for further replies.
   / Battery based electric vehicles of today and tomorrow. #581
What would gasoline cost you to drive the same number of miles in a month?
I answered that in https://www.tractorbynet.com/forums...c-vehicles-today-post5612743.html#post5612743
At $0.18/kWh my 380 Wh/mile Model S costs $0.0684/mile. Divide that into your cost of gasoline to get the dollar equivalent MPG. At $4/gallon it is 58.5 MPG.
$-per-gallon / ( $-per-kWh times 0.380 kWh/mile ) = dollar equivalent MPG
Replace 0.380 with 0.260 for the newer more efficient Model 3.
Math Is Hard
   / Battery based electric vehicles of today and tomorrow. #582
but you have to recharge a Tesla every day. I fill my truck once a week or less
No you do not "have to recharge a Tesla every day."
No different than a truck, you only replenish what you use.
It is best to plug in every night so that every morning the vehicle is ready for whatever comes its way.
   / Battery based electric vehicles of today and tomorrow. #583
Math Is Hard
well my Dodge diesel Ram gets between 24 to 27 mpg . Our diesel is 2.89 right now. I need to get my calculator. But first I need to calculate cost of vehicle into the factor. I paid 25,000 for rig in 1994. Has 370,000 miles and still going strong. What does a Tesla cost?. Also I’m not sure what cost is involved when batteries need replacing. Too many variables for a stomach filled with xmas food
   / Battery based electric vehicles of today and tomorrow. #585
Tesla batteries are currently estimated to serve 300,000 to 500,000 miles. As with engines and transmissions some have failed earlier.
   / Battery based electric vehicles of today and tomorrow. #586
Yes but new elements are not what has driven battery (or motor) advances.
Even today's lead-acid batteries are better than those of 10-20 years ago.
Check again. The watt hours per pound of lead acid battery has not changed in over a century.
Would you quit spinning the fantasy that 妬f the goal is noble enough and enough research is done , the laws of physics can be broken ?
   / Battery based electric vehicles of today and tomorrow. #587
I expect you know your post is misleading mixing religion and science.
As of today not every element on the periodic table is used to make lithium ion EV batteries so there is room for new battery materials in the future.
Alas I was concerned that you failed to understand and you have proven it in Spades . Every possible anode, cathode and electrolyte combination has been tried. Best typical capacity is 240watts per Kg, 280watts if you don稚 mind risking thermal runaway .With an absolute theoretical max of 400watt hours per Kg .
That痴 it, done nada .
   / Battery based electric vehicles of today and tomorrow. #588
if you use up the full capacity of the battery everyday, which is not hard, then you have to recharge it overnight everyday..
   / Battery based electric vehicles of today and tomorrow. #589
Status
2017 Bobcat E32i Mini Excavator (A50322)
2017 Bobcat E32i...
Frontier AB13D Hay Spear (A50120)
Frontier AB13D Hay...
Kubota RTV1140 (A50121)
Kubota RTV1140...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
JCB Wheel Loader (RUNS) (A50774)
JCB Wheel Loader...
W&A 3pt Ditcher (A50121)
W&A 3pt Ditcher...
