Branson 4815C PTO Dynamometer Test Results
   / Branson 4815C PTO Dynamometer Test Results #1
K5lwq
Elite Member
Mineola, TX
Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
This thread will be the results from a series of PTO Dyno test before and after modifications to the Branson 4815C. All thoughts and comments are welcome. Also, please feel free to post any Dyno results you may have for your tractor. I have been guilty of speculating or taking manufactures word for hp ratings and decided it is time to get some facts. I am very surprised at the initial test results!
Branson 4815C, Kukje A2300N2 diesel engine. 48hp claimed engine output and 40hp claimed at the PTO at 2600 RPM.
First test results with only 9hrs on the tractor and stock is 35hp at 540 PTO RPM. It hit 36hp when loaded down to around 500 PTO RPM but fell off quick after that. Net result is 35hp tested PTO hp.
Unfortunately, the location that did the test was not able to provide the graft as they don't have the printer for the Dyno.
I would have bet money that it would have been around 42 PTO hp and would have lost money. I do think it will get better as the engine limbers up some but sure thought it would be higher.
Next test will be after replacing DPF with standard muffler. Not sure if there will be a difference but seems like I should see a 10% increase. But, what do I know? :laughing:
   / Branson 4815C PTO Dynamometer Test Results #2
Not all dynos read the same or give the same results. If you repeat the same testing procedure on the same dyno, you should at least have a good comparison.
I agree and that is the plan. After the modification and we test on the same dyno, I might go to another location that can give the print out.
   / Branson 4815C PTO Dynamometer Test Results #4
Very interesting thread. Thanks for doing this. I wish there was a shop around here that could do one. To my knowledge there isn't, but I must confess I haven't really searched for one either.
Is this shop at a tractor or ag equip dealer somewhere in your area?
Yes Slim, it is at my local JD dealer. The Kubota dealer in Longview said they would test as well and they can give the print out. The reason I didn't go there is because it is an hour away and JD is 10 minutes. I might be lazy!
   / Branson 4815C PTO Dynamometer Test Results #6
Cool! Thanks for doing this and posting the results here!
Interesting results indeed. I'm sure it will get better as the hours start to accumulate.
Correct me if I'm wrong, but dynamo-meters are also calibrated for a certain HP range where they are more accurate, right?
There was a post on Branson Facebook group from a Branson technician where they tested a 4520R (same A2300N2 engine) with over 600 hours and it made 43 HP at the PTO.
Anyways, looking forward for the runs after the exhaust mod. :thumbsup:
   / Branson 4815C PTO Dynamometer Test Results #7
TQ. Numbers would be interesting to see also.
   / Branson 4815C PTO Dynamometer Test Results #8
It would be beneficial to know when the dyno was last calibrated, and what the results were. I worked at a repair shop once, and the dyno was used mainly to test tractor engines under load. The HP readings were not accurate for sure!
   / Branson 4815C PTO Dynamometer Test Results #9
Is your 4815 engine a turbo triple or non turbo four? Bransons' web site says it's a triple but the bore, stroke and displacement listed match that of the 4520 which is a four. When I was shopping Bransons they'd just come out with a high HP model of the 15 series (can't remember if it was the 4815 or another one) which had a turbo triple. Of course that was three years ago and they might have changed.
I am not sure about the calibration. Also would be interesting to know what the variances from one dyno to the next. I would think they would be close but not exact.
Torque was difficult to read as it changed more rapidly than the hp did. This is because hp is a calculation of the torque measurement. Hp= (torque x rpm)/5252
The dyno showed hp in whole numbers which is why it was easier to watch. But the torque was in the 345 ft lb range so that would make it around 35.47 hp.
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
Compressor (A55973)
Compressor (A55973)
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
Dayton 32965 80-Gallon Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
