Water Well 101......A few questions from a water well newbie
   / Water Well 101......A few questions from a water well newbie #1
Rmally
East Tennessee
RK 55 Hydro
Hey folks,
We are about 3 weeks from moving in to the new house. Next week they are moving the pressure bladder tank to the crawl space and will be hooking up the water. Here's my questions:
1. When the pump cycles if your in the shower do you loose a lot of water pressure?
2. Can you use multiple faucets with good pressure?
3. How do I know the optimal setting for setting the pressure in the bladder tank? I've watched so many videos but still confused.
As of right now the tank is still outside beside the casing. The air pressure in the tank is around 30ish lbs and it appears when the tank hits 30ish it fills back up and cuts back off around 55 or 60. I'm getting 12-14 gallons a minute with a 1hp pump. I noticed this week when rinsing off some equipment the pressure from the hose dropped off dramatically every time it cycled. I was using a lot of pressure and water so nothing like a shower head but that got me thinking about the above questions.
My tank is 25 gallons, should I get a bigger one for the crawl space.
Any input would be great.
Thanks
   / Water Well 101......A few questions from a water well newbie #2
I would suggest that you go to a larger tank. I have a 40 gallon tank with the pressure set to turn on at 40 psi and off at 80 psi. You can adjust the pressure switch to work in a tighter range, but that will cause the pump to cycle more often which shortens the life of the pump and controller.
   / Water Well 101......A few questions from a water well newbie #3
Yup.....use the largest tank that you can practically fit in your space.
Excessive pump cycling kills pumps over time.
   / Water Well 101......A few questions from a water well newbie #4
Probably too late but they make 3 phase pumps that are variable speed. They maintain pressure very well and only need a small 1 gallon pressure tank.
In your case the 30 psi spread is too much. You can get that down to 5-15 psi with the pressure switch. Too tight and the pump cycles on and off a lot- this shortens then pump’s life. Too far apart and you notice the pressure difference when showering etc.
I assume the pump contractor just gave you a temporary setup to get you water. When he hooks it up in the house he will set it up to where you hardly notice the pressure changes. I’m guessing this is a non issue when it’s all done.......after all, you hired a good contractor!!!
   / Water Well 101......A few questions from a water well newbie #5
In your case the 30 psi spread is too much. You can get that down to 5-15 psi with the pressure switch. Too tight and the pump cycles on and off a lot- this shortens then pump痴 life. Too far apart and you notice the pressure difference when showering etc.
I assume the pump contractor just gave you a temporary setup to get you water. When he hooks it up in the house he will set it up to where you hardly notice the pressure changes. I知 guessing this is a non issue when it痴 all done.......after all, you hired a good contractor!!!
"3 phase pumps"?
How many private residences have 3 phase power?
   / Water Well 101......A few questions from a water well newbie #6
Go with a bigger tank for sure. We had an 80 gal one that was upgraded from a 40 gal.... you could definitely tell the difference. Also, the pressure range should be around 20 psi difference for the low cut in and the high cut off. That difference can occur at any pressure range, just not more than around that 20 psi figure. Ex: 35-55 psi, 40-60 psi, 60-80 psi,..... it can be a little different like 18 psi or 22 psi, but not higher ranges like 30 or 35 psi spreads.
Also make sure they put in multiple check valves. At least one before the tank, another after the tank. There should also be check valves about every 100 ft in the well line both in the well and the line feeding to the house. Not sure what those distances are...
In the long run, you will get it all dialed in.... congratulations on the new house completion!
   / Water Well 101......A few questions from a water well newbie #7
I would suggest that you go to a larger tank. I have a 40 gallon tank with the pressure set to turn on at 40 psi and off at 80 psi. .
Was yours a bladder tank? I didn't know they made them that big. At my last house I think I had a 10 gallon, and it was more than sufficient.
As far as pressure goes, that depends on what your pump will put out. I had a shallow well, and the pump I had wouldn't do more than 45 psi or so. Again, totally adequate for anything I needed/wanted to do. Why do you need that much pressure?
   / Water Well 101......A few questions from a water well newbie #8
Yes, the 80 gallon tank has an air bladder. It is set at 2 psi below the pump turn on pressure. As far as the pressures, those settings were put in by the original installer 50 years ago. In those 50 years I have had to replace the pump once because it died of old age and the tank once because of a leak so I can't complain much. I don't have access to the county water supply, but they typically run at 80 to 100 psi.
   / Water Well 101......A few questions from a water well newbie #9
"3 phase pumps"?
My parents have one of these from Grundfos, it has a variable frequency drive that ramps the pump up and down according to demand. The motor in the pump is 3 phase so that it can be controlled by the drive, the drive is powered by 220v single phase.
I have the same setup on my drill press.
   / Water Well 101......A few questions from a water well newbie #10
To reduce pump cycling, consider CycleStop.
For your pressure tank with bladder, set the bladder psi to 2lbs below the cut on pressure (38lbs if your pressure switch is 40-60).
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
2006 Volvo VNL (A52748)
2006 Volvo VNL...
Vermeer WR-20 8-Wheel Rake (A50774)
Vermeer WR-20...
John Deere 6115M (A50120)
John Deere 6115M...
