Pallets in fields
   / Pallets in fields #3,532
Someone needs to built a machine that inputs pallets and outputs toilet paper.
Bruce
   / Pallets in fields #3,533
Bruce
Not a bad suggestion! Kill the Bturds and make TP out of them.
   / Pallets in fields #3,538
Or something that recycles TP! That's the way of the future. Recycling!
Just make sure it's actually RECYCLED, not just re-used. While re-use is higher up the chain than recycle*. it's not for everything...
The Golden Rule is:
1. REDUCE
2. REUSE
3. RECYCLE
   / Pallets in fields #3,539
Courtesy 2Lane.
   / Pallets in fields #3,540
Don't know if this is the best place to ask this, but couldn't find a better place.
I have noticed over the past few years that the local farm fields get populated with a pair of pallets leaned up against each other to form a inverted V shape. they are always out near the middle of the field, in a line, and about 500 to 700 feet apart.
Now during the Spring and Summer they are nowhere to be seen, and in late Fall they are out there again. As far as I know (not having been out in the middle of these fields) from driving by every day there is nothing out there that needs protection such as a irrigation pipe, so I can not figure out what purpose they serve. No one is out in those fields over the winter to do damage to anything except maybe some one riding their snowmobile if we get measurable snow which is not too common here.
Could someone explain the reason for these? I see them on more than one farm throughout our county.
I think this member should get some sort of prize for "oldest still running thread."
The pallets are there to use next year when two pallets are needed to lean on each other.
2020 DRAGON ESP...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56438)
Michelin CARGOXBIB...
2021 KOMATSU PC490LCI-11 EXCAVATOR (A60429)
2021 KOMATSU...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
