GOODYEAR R14T Hybrid/Crossover tires
   / GOODYEAR R14T Hybrid/Crossover tires #1
Darryle
Weatherford, Texas
John Deere
Has anyone tried these tires? Thoughts? Experiences?
It seems to be a great option for those of us that have the R4 style tire/wheel combinations and desire better traction in the field.
Thanks
   / GOODYEAR R14T Hybrid/Crossover tires #2
on the test done by messners [on grass] they weren't much different than the R4s ??
Well, how did they perform on plowed soil? I am not concerned about grass except for the spring when I do run the brush hog.
   / GOODYEAR R14T Hybrid/Crossover tires #4
the test was done on grass, no noticeable improvement on the load cell,
   / GOODYEAR R14T Hybrid/Crossover tires #5
for maximum traction on plowed ground , you would go with R2s, and then R1s, [in various degree options]...the R4s will tear less, and be a smoother transport tire on hard surfaces... just my opinion based on 20+ years doing this crap for a living..
I have seen one set of R2 tires in my life and that was at an auction in Howe, Texas years ago.
I have always ran R1 tires, radials in the later years before giving up farming for a Government job in the late 90s.
I am trying to avoid buying wheels and tires and this appears to be a better option. I could care less about road worthiness of any tire at this juncture of my life. This tractor will see haying duties in the winter, mowing in early spring late winter, tillage in the spring and road maintenance yr round.
   / GOODYEAR R14T Hybrid/Crossover tires #7
My 2400 came with R4s. I installed R1s on the rear, changed nothing else (but wheel from 16.5 to 16) and traction is day and night.
   / GOODYEAR R14T Hybrid/Crossover tires #8
I made it a point to get the R14's on my RK55, it was a '20 add to the available tires. So far I'm impressed, grass not torn up like I thought might be the case. Dirt traction looks good so far.
   / GOODYEAR R14T Hybrid/Crossover tires #9
I'm thinking hard about ordering a set of 12.00-16.5's for my MF. I found them on ebay today for $125 a tire new, with the branding buffed off. Pretty sure I know who made them... :)
They're listed as R4 rather than R14, so you have to search around a bit... :)
Hoping for good snow traction, mostly. Hate chaining up, and with my almost bald 10.00's, anything would be an improvement any other time of the year. No turf to tear up, and our clay is hard as a rock in the summer.
The ebay tires are only 4 ply rated, but I don't care, as I run my current 10.00's at 15-18psi anyway for a bit more traction and flotation. With a 12.00 on the narrower 8.25" wheels, I'll probably be fine at 15psi without worry about pushing one off the bead.
The same ebay "store" has Goodyear R4 16.9-24's (also with the name buffed off) for a good price too, so I'll probably do all four at the same time and be done with tires for a good long while. My rears are currently 17.5-24's, so I should end up with a bit more lead than I currently have, which would be nice.
I'll get some pics
   / GOODYEAR R14T Hybrid/Crossover tires #10
BTW, I'll agree that if this tire had the voided lugs present, it would be an excellent snow tire, and pretty good at everything else, except perhaps all out R1 territory.
Heavy Duty Solid Steel Skid Steer Mounting Plate (New/Unused) (A59225)
Heavy Duty Solid...
2020 Case CX80C Excavator (A59814)
2020 Case CX80C...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
UNUSED 1RMC HIGH END MASSAGE CHAIR (A58376)
UNUSED 1RMC HIGH...
2016 Kia Optima Sedan (A56859)
2016 Kia Optima...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Super Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
