Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #14,201
C&K shingle is just trying to get his front end working, $500.00 for new axle.........
^^^^^^^^^^^^^^^^^^^^^^ Before the new axle gotta dig out all the metal shavings.
   / Tractors and wood! Show your pics #14,202
My Ranger is ticking down it's last few miles, and I'm considering an F-250 that I can put a dump body on. It will only haul about 3000 lbs but that's a yard of gravel or 1/2 cord of firewood... all that I really need for my purposes.
Two years ago I started reclaiming gravel from a road on the other end of my property to build a pad for my tractor shed... 3/10 of a mile each way, one bucketful at a time. I usually got a couple of trips per night at about 1/3 yard per bucket. It started snowing before I got done, so last year I bought a load of gravel. I don't remember what I paid but it was cheaper than wear and tear, plus the diesel I was burning.
I'm doing the same thing on my bridge and rest of the new woods road, one bucket at a time, 2-400' each way in 2nd or 3rd gear, almost done now.
   / Tractors and wood! Show your pics #14,203
I used to do one bucket full at a time like you guys are talking. Can be slow going but it will get done.
Then I bought a used 3000 lb dump trailer and do it this way. There's Pike crusher plant 1-1/2 miles down the road. Two yards of 3-1/2" road base for $28. Trailer can take a one yard load. So one trip to Pike's and two trips out in the woods fill in a mud hole.
I keep looking for some gravel here but it is all silt and rocks.
gg
   / Tractors and wood! Show your pics #14,204
gg
That bucket looks bigger then mine at 5' wide. I like that saying> ......it will get done. You have a great setup GG. So your paying $14.00/yd, I have no doubt that I already moved 50 yards since April, an excavator help me back in May to loosen up the dirt, rocks and boulders that I have, looking for gravel, then it's the ledge I have that really gets in the way. But what really grinds my gears is just two miles away theres probably 3000 acres of gravel....:hissyfit:
   / Tractors and wood! Show your pics #14,205
For some reason the next ten years crossing my bridge this guy is going to come to mind..........
   / Tractors and wood! Show your pics #14,206
If you have moved 50 yds of gravel ( that's quite a bit a bucket at a time ) then getting an excavator in there was a good thing to do. Moved the big rocks plus gave you tractor access to all that material.
gg
   / Tractors and wood! Show your pics #14,207
Thanks, it's nice seeing a project come to a end, it seemed like all the prep work was more work then making the bridge it self.
Prep work is always the hardest!!
   / Tractors and wood! Show your pics #14,208
I would really be surprise to see 1600 lbs each to go very far but I'll know for sure next March, thats the true test.
I hope you are OK but I would have anchored or keyed it into a foundation in some way. Houses are really heavy but there is a reason they fasten them to the foundation.
   / Tractors and wood! Show your pics #14,209
gg
Yeah, all mine is one bucket at a time, wish I had gravel here too, its all just sand here!
   / Tractors and wood! Show your pics #14,210
I wish I had gravel too, it's all rock and clay, we are close to Hudson River, so when that glacier/iceberg carved its way down, this is where it deposited all the junk it dug up. At least that's what some experts say happened. I wasn't there and there's no pictures so I don't know.
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
2013 FORD F-350 (INOPERABLE) (A58214)
2013 FORD F-350...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
(4) HD ALUMINUM RIMS (A58374)
(4) HD ALUMINUM...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A58214)
2012 SOUTHERN VAC...
JOHN DEERE HAY CUTTER (A58216)
JOHN DEERE HAY...
