Buying Advice My experience with Washington PA RK store
   / My experience with Washington PA RK store #1
benktsv
Kubota L3901
About a month ago I considered buying RK55 in Rural King near Washington PA. Talking with the repair guys in the store, did not sway me one way or the other. But here is what did:
Around the same time, I bought a Stihl blower from the same store.
First day on the job site the blower would not start. Brought it back to the store and they said that it will be repaired within a day or two and I will get a call.
Two weeks later, no call. I went to the store and a person at the Stihl stand told me that their repair man said there was nothing wrong with the blower. They adjusted carburetor and it is better than new now.
I tried to start the blower right there and it would not start. I asked for replacement. The person called front desk and I hear the front desk is telling her that they would have to try to repair it again. I go to the front desk requesting replacement. The manager came and said that repair guys claimed that I flooded the carb on the blower, but they fixed it. OK, but here it does not start again and I did not even take it out of the store. After a long, senseless, argument they did replaced the blower.
So, will I take a chance on $32,000 tractor when the store can稚 handle a $300 blower? I think I will go with a real dealer.
   / My experience with Washington PA RK store #2
At the very least I'd hope the blower repairman isn't their moonlighting tractor mechanic.
   / My experience with Washington PA RK store #3
No RK around here, but my stihl dealer is shoddy at best. My stihl 170 chainsaw is hard to start on the best of days after numerious service calls. My husqvarna has been flawless since the day i bought it 8 years ago, second hand.
   / My experience with Washington PA RK store #4
My Stihl blower takes 5-6 pulls. It is annoying as heck.
My Stihl ms362 starts on the second pull.
   / My experience with Washington PA RK store #5
I have had a Stihl for 30 years!
Great saw, but OFTEN very hard to start.
My Still now sits quietly on the shelf.
I never need to mix fuel.
My 40V Greenworks saw starts every time...just need to push the on button!
   / My experience with Washington PA RK store #6
Same, except 80V tools. Still like my Husqvarna 372XP for going through >36" oaks though...
   / My experience with Washington PA RK store #7
I now have four Stihl products believe is all. Two saws from 3 to 4 years old and string trimmer on wheels about 2 years old and a leaf blower my father in law bought in the 90's. The first Stihl saw I bought they ended up replacing as it truly burnt up due to carburetor I think. Dealer said no warranty by Stihl for that but when I complained to Stihl they had dealership replace it. Another shop said the damage was a sign of too lean fuel mixture.
I like to totally learn how to start a Stihl saw and from a field called the shop and asked the owner please walk me through the process, since then have had very little issue doing so. Place on full choke and pull once or twice but never past when it gives first sound of wanting to start. Then either cut the choke off fully or at least to the sitting that is not full choke and mine have been faithful starting that way. They seem to flood very quickly on full choke an if they do for me best to set them down and find another tool or job for a few minutes. I do believe Stihl works better with higher octane gas than my other 2 cycle engines do. Had a dealership of to me all the major brands tell me the best fuel for two cycle engines is aviation fuel. He said they really need the octane of it and had a second dealer say about the same but no mention of aviation fuel.
   / My experience with Washington PA RK store #8
I have about 6 Stihl Combitools, blowers & hedge trimmers. All are very easy to start. Small climbing Stihl chainsaw, easy to start. Had a large Stihl chainsaw, so hard to start I gave it away
Andy
   / My experience with Washington PA RK store #9
The "aviation fuel" is 100 octane Low Lead.
It works great, but the older I get the better I like voltage "fuel". Always starts, with the push of a button, and I don't need to drive to the airport to get it.
   / My experience with Washington PA RK store #10
You running a 24" inch bar on that button model?
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2018 FORD F-150 (A53843)
2018 FORD F-150...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
