Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #14,453
   / Tractors and wood! Show your pics #14,454
Now let me see you scoop up a bucket of dirt with that......................... I always thought the best combo was just a thumb on the bucket but then I dont know if a bucket can be used to dig up dirt with thumb on, so if I put a thumb how hard would that be to take off and put back on. One thing I do know is that I need a bucket on a tractor cause I'm always using it to move dirt. Hi my name is repeat, I need a bucket on a tractor.............
Scooping material from a pile is no problem. Digging depends on the shape hole you need. Going straight down with bucket to get a steep edge in a deep narrow hole can be awkward. Not to deep is easy. Long deep trench a bucket wide is easy.
But get one that detaches easy. Mine comes off with 4 bolts each side or I can just take the lid off with 3 pins and two more for the cylinder. I've only had to take mine off a couple times.
gg
   / Tractors and wood! Show your pics #14,455
gg
Yeah something like yours is what I like, I dont mind the bolt on bracket but why cant they make it so just the cylinder and thumb be un-pined and removed.
But for now I have put it on my bucket list and focus on a dump trailer about the size of what you have, I just dont know whether to buy or try to build. Without a grapple I can move brush, load logs, load dirt, unload logs but I cant unload dirt.
   / Tractors and wood! Show your pics #14,456
I have Greens Machine Thumb. It is designed to be removed just by disconnecting the hoses and unpinning the Thumb. The price and weight are also quite low.
Shop Online
   / Tractors and wood! Show your pics #14,457
BWAAHAHA Good one!!!... Bucket list!
   / Tractors and wood! Show your pics #14,458
Shop Online
That sounds picture worthy or you dont post it enough. I did find a couple pictures of it online though and dont see much for mounting support. Not sure what Green has to do with the thumb.
   / Tractors and wood! Show your pics #14,459
That looks a bit lightweight all around, but it isn't designed to pick things up; merely hold them so that they don't roll off. It seems perfect for somebody who cuts a lot of wood, but also uses his bucket constantly.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2006 Dewatering and Drying Centrifuge (A56857)
2006 Dewatering...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
