John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,582
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
John_Mc - I had not thought about a hitch but now you have me thinking about one.
The Norse butt plate is flat so I suppose that would be a likely spot.
As long as the mounting does not interfere with the swinging butt plate that would probably work (isn't it Norse that has the swinging butt plate? I can't recall at the moment.)
Think about how high off the ground you want the hitch. Generally, I wanted mine mounted somewhat low (you can see some extra holes on the receiver mount in my photo. It's shown in an upper position. In actual use, I always mount it as low as it will go.) The lower you mount it, the higher you can raise your 3 pt hitch and still have whatever you are towing be reasonably level. This makes it easier to clear any waterbars or ditches you drive through. Too low and it may interfere with using your blade as a dozer, or getting it to dig in to provide an anchor on uneven ground, or you may not be able to raise your trailer's tongue as high as you would like as your tractor starts back up out of a ditch.
You can always use a receiver insert with some rise or drop to fine tune the height. I just wanted to avoid an extreme amount of height change with an insert, as this creates a longer lever for any load I'm hauling to crank on the receiver or winch. I set mine up to minimize any height change I anticipated needing.
