Any recommendations for LED floodlight/security light to hang on garage?
   / Any recommendations for LED floodlight/security light to hang on garage? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Want to light an area about 40x20 feet.
   / Any recommendations for LED floodlight/security light to hang on garage? #2
I don't have a recommendation but I do have an application for a security LED floodlight, solar powered, motion activated, in case anyone has a suggestion. Thanks in advance. Newbury, hope you don't mind me piggy-backing your post.
   / Any recommendations for LED floodlight/security light to hang on garage? #3
I'll be following. Need some kind of light on the far end of my carport.
   / Any recommendations for LED floodlight/security light to hang on garage? #4
18W LED Security Light, 18lm 5K Motion Sensor Light Outdoor, IP65 Waterproof ETL Listed, Dusk to Dawn Flood Light for Garage, Yard, Porch, Patio - - Amazon.com
We have had the above light since the start of July. It does a really good job lighting up the area. With it being LED, it is low power usage. We have this one set to come on as a dusk to dawn light.
Now if you want solar powered, we have these on our deck Aootek 182 Led Solar outdoor motion sensor lights upgraded Solar Panel to 15.3 in2 and 3 modes(Security/ Permanent On all night/ Smart brightness control )with IP65 Waterproof with Wide Angle(2pack) - - Amazon.com
Yet they aren't as powerful as the wired LED. Yet, they do well lighting up our deck and the last all night We have them set on a low light setting and when it detects motion it kicks up to high.
   / Any recommendations for LED floodlight/security light to hang on garage? #5
20 x 40 is not a very large area. Almost any LED will do that. I have a larger area than that lit with 3 small housing 5W floods I got at Big Lots. It isn't daylight, but it's enough I can see the entire area on the camera all night. If you're powering with 110 VAC line power, any basic flood type unit over 100W (10W or less) equivalent should be more than enough. If you want it to look pretty, it might cost a bit more.
I've never had much luck with solar units. They last a year or two and they're done.
   / Any recommendations for LED floodlight/security light to hang on garage? #6
   / Any recommendations for LED floodlight/security light to hang on garage? #7
I bought some of these and was amazed at how well they worked. No special light fixture needed. Motion sensors and light sensors 1200 lumens and only 13 watts and under $10 each.
They work best on driveways and parking lots where tree limbs blowing in the breeze don't set them off and only one light should be used in an area because 2 bulbs shining on each other causes them to not work properly.
https://www.homedepot.com/p/KODO-12...ght-Bulb-Daylight-2-Pack-1003032302/308185716
   / Any recommendations for LED floodlight/security light to hang on garage? #8
Really happy with our ring floodlight cams. They have a panic alarm you can activate. I've ran off 5 or 6 people at our business that showed up after hours that seemed to be up to no good.
   / Any recommendations for LED floodlight/security light to hang on garage? #10
I purchased an LED TUNNEL light. They use them to light tunnels. It's 200 watts but puts out the light of a 1,000 watt incondecent light.
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
KSI Conveyor (A55301)
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
