Travis_R
Could a bad injector or a leaking injector pump have caused this? The injector pump has had a decent drip for a while. I’m puzzled over this!
Do you had symptoms of a leaking injector?
A leak of diesel from the pump can't do this.
Knocking is a very common symptom, highly unlikely you have a bad injector with so low hours on the engine. Failed head gasket might come from over heating, low coolant level or that nobody retorqued the headbolts when it was new.
The problem with gauges are that without coolant they will not rise to hot even if the head is overheating. Does it never go into normal temp? If I remember correctly it has a green marking for normal working temp.
You could pressurize the rad with a hand pump and see where the coolant is going by taking out the injectors and seeing where it comes out of when you turn the engine over....BY HAND, not using the starter. Using the same method, you may see bubbles in the rad. If you are loosing coolant into the engine, be aware, it plays he77 on bearings.Are there any simple tests I could do to see what the problem is?
