Jinma 254 LH tie-rod
   / Jinma 254 LH tie-rod #1
Whenu
Member
Kaitaia,New Zealand
Jinma 254
Hi all, my tie-rod broke at the thread. Can anyone confirm the size of the taper? Mine is 17.5mm to 19mm and the rod ends I've seen on line are a 14/16mm. The thread on the ram is 20mm.
The small piece I think is the remnants of a nut? It may have a slight taper.
   / Jinma 254 LH tie-rod #2
Why is the nut so worn?
   / Jinma 254 LH tie-rod #3
That rod end doesn't look like it's been connected to anything in years. Or it's been rattling around in the arm. Don't match that part. Match the new rod end to the size of the arm taper. The arm is probably hosed too if the rod end looks like that. :eek:
You may have to take a tapered reamer to the arm to clean it up. In the U.S. the tapers are designated in inches per foot. I don't know what that thing would be. :confused:
   / Jinma 254 LH tie-rod #4
Picture not the best. what is the standard dia of the hole, and could it be sleeved?
The tapered section seems to be ok.
Tried the local tractor dealer on the off-chance, nothing there, but wasn't expecting much.
Have ordered one from Oz.
Might try and bodge up a repair for an emergency spare.
   / Jinma 254 LH tie-rod #8
you don't have a local Jinma dealer?. then you have bought the wrong brand of tractor..
At the edge of the world, we don't have the luxury of driving to the corner tractor shop, we make do with what we can.
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2012 Cat D6T XL Dozer (RIDE AND DRIVE) (A50774)
2012 Cat D6T XL...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2017 John Deere Gator TS Utility Cart (A50322)
2017 John Deere...
1986 East Tri Axle Semi Dump Trailer (TITLE DELAY) (A50774)
1986 East Tri Axle...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
