Boy, how they grow
   / Boy, how they grow #1
TnAndy
East Tennessee
Yanmar LX410...IHI 35J excavator Woodmizer LT40
We've gotten Duroc feeder pigs the last couple years, and they seem to out grow about any about any breed we've ever had before.
Here they are the first week of May....couple of 30lb weaned piglets. Our Border Collie is around 50lbs by comparison.....and trying to herd them.
enhance
Killed the first one this morning....he weighed 430lbs. Will do the other one in a couple weeks. He looks a bit smaller, but by then, should be pretty close to this one. I started about 7:30am, and had him hanging in the walk-in cooler by 9:30. Will start cutting up tomorrow morning after it chills overnight.
enhance
enhance
enhance
   / Boy, how they grow #2
Do you render lard? Looks like it has a good layer there.
We do. Cut into 1" cubes and render in crock pot. Also brine cure my hams and bacon.
   / Boy, how they grow #4
Are you using all bought feed or feed and whatever from the garden.
I hope to be able to raise a hog or two myself this next year.
We buy commercial feed from the local Co-op, (Couple bags of 18% 'starter', then move to 16% 'grower', finally 14% 'finisher') plus they get excess eggs from our chickens, garden leftovers, and this time of year, lots of apples they really love. In addition, they will go thru a couple 4x5 round bales, and I have them on a 50x200' pasture lot of clover/fescue.
Housing can be very simple.....my first ones many years ago, I simply turned up a few pallets with some sheet metal over the top. Later built a hog house with wood floor with hinged top can be raised to clean out between occupants. I'll throw couple bales of hay in for the new piglets to burrow in, and by the time they are grown, they will have eaten all of it.
enhance
Later added a small shed at their lot to hold four 55gal drums for feed plus a trough made of hunk of PVC sewer pipe split in half. Makes it handy to store feed and feed without getting in the lot.
enhance
enhance
The result is meat you can't come close to buying, and pigs that have a great life while they are here. Hope you get the chance to raise some !
enhance
enhance
   / Boy, how they grow #6
Nice setup!
You are right, the absolute best pork i every had, was grown in our pasture! We dipped ours in hot water and scraped the hair off. Rendered the lard, processed a number of hams, pork chops etc. Fried the skin in lard.
   / Boy, how they grow #7
Do you free feed, or give them a set amount each day?
Set amount each morning. I watch the feed trough.....if they haven't cleaned up from the previous morning, cut it back a little.....if licked clean, add a little more. Here at the end, was feeding about 3 gallons (dry measure) a day between the two.
   / Boy, how they grow #9
I'm feeding 50 lbs every two days, and mine are about 50 lbs smaller than yours. They do clean it up though, and if I feed less start looking for more.
   / Boy, how they grow #10
Our Duroc crosses always POPPED at about 50 pounds,going from 50 to 100 in what seemed like a week. Our Duroc sow was one of the sweetest, most docile pigs we had. She punctured a back leg on something in a wallow at about 700 pounds and got an infection in the bone that we couldn't clear up. She wasn't able to bear weight on that leg and was essentially immobile so we had to euthanize her, it was a sad day as our breeders are more like pets.
Try getting your fat to almost frozen and running it through the meat grinder before rendering it. I found this to allow it to render faster and more completely but, you don't get the larger cracklins this way. I would load my fat into a cast iron Dutch oven and put it into the oven at 215F, this was just hot enough to boil out any water but not hit enough to burn the lard. I'd ladle the lard out hourly and add more fat. I liked to filter my lard through 5 or 6 layers of cheese cloth, my leaf lard would come out pure white and odorless.
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A52377)
2019 John Deere...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
