Getting Wifi to detached shop 120 feet from house?
   / Getting Wifi to detached shop 120 feet from house? #1
Rock Crawler
Pittsburgh, Pa.
2021 Kubota L3560 HSTC, 2011 Craftsman Excellerator GT (680hrs), 2018 Husqvarna TS354XD, 2017 Husqvarna HU800AWD, 2019 Kawasaki Mule Pro DX (Yanmar)
My buddy has Comcast internet and wifi at his ex wife's house, he still pays. The parcel is split and his 40x60 shop is back and to the left of the house as your looking from the road.
The front of the shop is about 100 feet behind the back wall of the house and the shop is about 40 feet to the closest back corner of the house.
The internet wifi is not at all available from the Comcast thing, and he wants to put up Ring or similar wifi cameras that would alert him if someone broke in.
What can we do to supercharge the wifi and cover that building? It's not that far, so I'm thinking that there is some way to buy a better wifi box than the included Comcast one and magically cover that shop in internet.
Have any of you tried to get your internet to cover out over an added garage?
I've attached a picture showing the 2 parcels, the wife's house and his shop parcel. Screenshot_20210116-122227_Maps.jpg
   / Getting Wifi to detached shop 120 feet from house? #2
There are lots of long range antenna solutions on Amazon. Either a parabolic antenna on the house pointed at the garage, or two high power units or panel antennas should do your body just fine. In general 2.4GHz has better range, but with parabolic antennas, 5GHz works well, and has less interference.
All the best,
Peter
   / Getting Wifi to detached shop 120 feet from house? #3
Sounds like a mesh wifi setup is in your buddies future.
Google mesh wifi and you will get a ton of info.
Repeaters are another option but my experience with one to get a signal to my generator outside behind the house, they cut speed. Mine cut speed by half. That was OK for this application, but my recommendation for what is described above is go with a mesh setup.
   / Getting Wifi to detached shop 120 feet from house? #4
Is asking the Ex to move her WiFi box or adding an extender to the nearest corner of her house an option? I have a good signal at 100 feet line of sight. Does the shop have metal siding?
   / Getting Wifi to detached shop 120 feet from house? #6
Agree extenders are inexpensive and "should work" depending on the construction as Jetho points out.
We are on Comcast 200MBS service and have a house, garage and barn all wood frame construction - wifi is in the garage loft - distance to back of house 100' from garage and wifi router we get 30MBS, distance to barn 210' get 15-20MBS outside barn, a low signal inside but OK.
We are using a 3.0 cable modem, and a Netgear 1900AC router for 3 years, it replaced a older netgear router and extender setup in the house which worked but not as reliable as the new Netgear router.
   / Getting Wifi to detached shop 120 feet from house? #7
My son built a "Pringles can" type antenna to get internet from my house to his house 500 feet away. It worked very well. Just Google "Pringles can internet".
   / Getting Wifi to detached shop 120 feet from house? #8
It doesn't have to be high-tech.
How To Make a Wi-Fi Antenna Out Of a Pringles Can
When I was in grad school years ago, a buddy of mine did this so he could beam his wifi connection to his friend that lived a couple apartment buildings away (with line of sight) so they could split the cable bill.
   / Getting Wifi to detached shop 120 feet from house? #9
I purchased a Linksys RE6500 used for $15 works better than I expected.
   / Getting Wifi to detached shop 120 feet from house? #10
I use a GL AR300 EXT travel router piggybacked on a ZTE Velocity on AT&T. I have everything on my home network connected to the little travel router including a wifi camera 400 ft from the house. I think I paid about$50 for the router.
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
BELSHE DT-235 (A53843)
2018 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2018 Allmand...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
