Snow snow removal with Kubota BX2200
   / snow removal with Kubota BX2200 #1
Anonymous Poster
Epic Contributor
Does anyone have experience using a snow plow blade on their BX 2200?
Would you suggest chains, wheel weights, and/or tractor weights to do the job more efficiently.
Some parts of my asphalt driveway are steep. On my old tractor, 2WD, I had to use chains, etc and still there was a good deal of slippage and wheel spinning. The BX is 4WD.
Thanks,
Warren
   / snow removal with Kubota BX2200 #2
First, let me extend a warm welcome to the forum. Stick around and you will learn alot, I have. Secondly, its hard to answer you question because you didn't give us all the information needed. I noticed you are not registered. If you had been I would have checked your profile for additional information.
Do you have hills, steep drives? How far north are you? How many times does it snow where you live?
If you have hills, you will need chains. If you get sleet and or ice storms, I would say chains would be helpful. I have a 2910 with loaded tires and still need chains on my hilly terrain.
A front blade works well as does a back blade. Some quys use their FELs with good results for light infrequent snows. If you live in the snow belt a blower, either back mounted or front mounted would work well on your asphalt drives.
Again, welcome /w3tcompact/icons/smile.gif
Rick
JOHN DEERE 6180CI510 LOT NUMBER 244 (A53084)
JOHN DEERE...
JOHN DEERE 1814E LOT NUMBER 257 (A53084)
JOHN DEERE 1814E...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2006 Pierce Fire Truck (A51692)
2006 Pierce Fire...
