pallet forks
   / pallet forks #1
dodgeram55
massey 2400
i have a new gc1723e massey looking for pallet forks any body got any suggestions
   / pallet forks #2
Check out HLA 36" Forks, there about the lightest you'll be able to find and a good fit for a subcompact that has limited lifting capabilities.
   / pallet forks #5
There have been comments about forks being too long. I wish mine were a little shorter.
Also, I bought Skid Pro because it is made in usa ......... only to find a made in china label on the forks themselves.
   / pallet forks #6
If you are handy with a welder, you can fabricate some forks. I made some with 2x4 steel channels.
   / pallet forks #7
Since I rarely use pallet forks, I just made some out of PT 2x4s. No, not rugged, but they just slip on and work fine for objects up to about 200 pounds. Cost, about $20....
   / pallet forks #8
What I think would be more handy around here are debris forks for brush, wood, timbers, etc. More expensive than pallet forks, with more tines, but look really handy. I think I will go shopping! :)
   / pallet forks #9
I'm in the market for some sort of Forks, I noticed the Debris Forks, they look interesting.
My only heart ache is the shortness of the Forks, does anyone know of a "Clamp-on Debris Forks" that have longer Forks ?
Looking for usable Fork Length somewhere around the 48" mark... not even sure what is a good length ! I'm willing to buy the heavy duty vision or at least the 4000-lbs. Forks.
The main use around my property will be moving brush, smaller trees, maybe some construction lumber, but mostly light weight stuff.
   / pallet forks #10
I bought MTL forks when I bought my grapple. I think I got $50 off for buying both at the same time.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
Here are some similar links:
