tycoonbob
Member
Hi all.
Family and I bought a house on ~5 acres back last fall. Since we've lived here, we've learned that there are some areas in the yard that water will stand, and it's becoming an issue. We have a field behind the house and the only way to get to it is to drive through the yard. I'm wanting to put a gravel drive, but it would go right through a place where water will sit. In fact, there has been standing water there for the past 2 months straight (in KY, so winter is here, but it's only gotten down to low 20s/upper 10s so far). I think a french drain system would do the trick, right? More specifically, Lowe's sells EZdrain by NDS, which should be as easy as trench, drop, cover.
What I'm trying to figure out is what is the best way to trench and how deep do I need to go. I have my Kubota L3560, but no backhoe. Neighbor has a bobcat and excavator I could use, but the smallest bucket he has is 24", so going to be more mess than anything. TSC has the $200 Middle Busters as well as the $200 Subsoilers. The MB may not go deep enough, and the Subsoiler wouldn't be wide enough of a trench (the EZdrain stuff is 8" in diameter). EA has their 18" Potato Plow (Potato Plow | Middle Buster by Everything Attachments) which should go deeper than the TSC MB, and be wider than the TSC Subsoiler. This ground is soft, full of clay, but not broken up before (that I'm aware of). Would something like the EA Potato Plow/MB be able to get me a 16" trench in a few passes? Should I drain to the ditch, dig a dry well, or just lay enough EZdrain and call it good (I've always heard a proper french drain system doesn't need an outlet; it will hold water until it can soak into the ground down below)?
I know I could rent a trencher, but I have several areas on the property that I'll eventually do this to, so I don't want to repeatedly rent a trencher, nor do I plan to do all my trenching in a single day. I don't mind picking up a $350 implement that will do the job, and find other uses for later.
I've got a few pictures in a Google Album that shows the area I'm focused on.
Drainage issues - Google Photos
The area is between the road and my shop, and also backs up to the blacktop driveway. My ultimate plan is to place a gravel drive from the blacktop, around the building and along the backside of the building to the fenced in field in the back. I took these pictures yesterday after a solid 14 hours of rain, so it shows how wet everything is right after a rain, as well as how much water the ditch sees. the ditch will run dry in a day, but that area in the yard will stay like that for weeks, even in the summer. Nasty to mow, and you can see tracks where I've driven my truck with a trailer through in a couple times, more than 2 months ago. What's the best way to get it dried up?
Any advice is greatly appreciated!
